Sounds like its overheating.
Causes:
1. Overheat
Most cases this is caused by a over heat where the system fan gets blocked or there is not enought air flow, this can damage the system cpu.
Other known causes
AC/ adapter needs to be replaced some case were found that the ac adapter would be the cause as well it would be something to have checked out.
Now if the system shuts off without the ac adapter and its running on the battery as well you might want to look at the overheat issue.
thanks for using fixya please do be considerate and post you ratings and feedback for your answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
