20 Most Recent Acer Aspire 7720 Notebook Questions & Answers
What are the key functions on top of my acer aspire 7720
Hi Shawna From the owners manual for the 7720, (Page 15) all of the functions of the buttons are listed. Just cut and paste this address into your browser. ftp://ftp.acer.at/notebook/aspire_7720/manual/Aspire_7720G_7720_EN_McAfee.pdf Hope this helps you out. -Steve
4/2/2015 4:25:44 AM • Acer Aspire 7720... • Answered on Apr 02, 2015
Acer aspire screen jumps from 100% down in 5% increments
u have to check settings in games and select appropriate setting while playing.
3/4/2015 6:11:39 PM • Acer Aspire 7720... • Answered on Mar 04, 2015
My screen is horizontal split into two screens at startup; How do I get my full screen back??
problem with the led screen, change it should solve the problem
12/30/2014 5:28:06 AM • Acer Aspire 7720... • Answered on Dec 30, 2014
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard (FP1 Pins)? Thanks!
Look onto motherboard there is marked as a name of pw btn--power button and plug in front pannel pwr cable pin here
9/30/2014 10:38:03 AM • Acer Aspire 7720... • Answered on Sep 30, 2014
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard?
If you have knowledge of computer hardware and also have a tool for open the computer cabinet, look at the 9 pin on motherboard one is shot out of ten pin, in the pin panel there is market some word to connect the panel Like Pw bt -Power button, Rst-Reset, Pwr-Led-Display Led, HDD-Hard disk Led, and SPK-Speaker Button. Inser all cable acordingly which is allready marking with coat sign
9/30/2014 10:29:50 AM • Acer Aspire 7720... • Answered on Sep 30, 2014
2answers
NUMERIC KEYPAD NOT SUPPORTED
Might give this a try-right click on your Computer icon-click on Properties-then click on Device Manager. The keyboard is listed there. If it has a yellow exclamation point, or a yellow question mark, then there is a problem. Click on the arrow in front of Keyboards, then right click on the drop down named keyboard. There you can click on update drivers. That should solve the problem.
9/25/2014 9:20:34 AM • Acer Aspire 7720... • Answered on Sep 25, 2014
Says password check failed system halted aspire 7720 laptop
If complexitity settings are not met or passwords written do not match, password change might fail. Try longer and more complex password.
6/4/2014 9:19:44 AM • Acer Aspire 7720... • Answered on Jun 04, 2014
2answers
Acer Aspire 7720 PC Notebook
pointed red circle
aaarwind_13.jpg best of luck...
4/12/2014 6:38:54 PM • Acer Aspire 7720... • Answered on Apr 12, 2014
7720 runs fine off battery ,but will not run off ac adapter ac adapter has been checked and has the right amount of voltage and amps
Adapter: see if you can get a duplicate adapter from someone and try theirs. Your PS has a fault which could lead to damage to the Video portion and down the road, burn out the CPU.
3/1/2014 11:55:23 PM • Acer Aspire 7720... • Answered on Mar 01, 2014
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop. Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
2/28/2014 3:55:56 AM • Acer Aspire 7720... • Answered on Feb 28, 2014
Avermedia a310 b
Please contact your local Acer tech support who will either guide you or refer you to a dowloadable setup guide.
2/11/2014 5:48:38 PM • Acer Aspire 7720... • Answered on Feb 11, 2014
Acer Aspire 7720 beeps after awhile
If it continuously beeps after every while, must be you have some alert on software running on background, check , could be temp alert, or if you have any antivirus software, it also leads to beeping whenever it finds a virus(sometimes). Hope this helps.
12/15/2013 7:52:19 PM • Acer Aspire 7720... • Answered on Dec 15, 2013
Webcam
4/29/2013 11:42:55 PM • Acer Aspire 7720... • Answered on Apr 29, 2013
Motherboard
I believe this is your motherboard click here My YouTubeFacebook
4/25/2013 12:35:04 AM • Acer Aspire 7720... • Answered on Apr 25, 2013
0answers
Internet conexionlocal only
Wired or Wireless? If Wireless will not connect, First try a test, using a Ethernet cable connect directly to the ISP modem, Does it connect? Yes or No? If yes, move the cable to the Wireless router, Does it connect, Yes or No? If no, Contact ISP. Check ALL cables to the ISP and Wireless device ,reseat cables. It may be the Laptop Wireless or wired adapter, reboot the laptop and the wireless device. I don't have all the info needed to supply a more percise solution. Try a IP release and renew using this procedure : http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/
1/30/2013 2:07:09 PM • Acer Aspire 7720... • Answered on Jan 30, 2013
Acer Aspire 7720 Notebook Logo
Popular Tags
239 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
trying find wireless
  • Computers & Internet
