You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player.
If you mean just the one and the rest then it was probably recorded in Extended Play mode and nothing can be done.
Otherwise please explain your issues in more detail.
Hi. Why is my VHS tape playing fast?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px; transform: rotateZ(-180deg);">
If you have a VHS video tape that's playing too quickly then it's very likely that the player you are using does not support either LP or SLP. SLP capable video players should automatically detect the mode and adjust automatically.
or try this link out.
https://www.manchestervideo.com/2017/09/15/faq-why-do-some-video-tapes-play-too-quickly/
You may think the tape has an hour of material on it, but the machine thinks otherwise. Either it didn't actually get recorded past the 11 minute point, or something erased the tape past that point. There's nothing to play after that time, so you're seeing the snowy screen. On most VCRs, the tape counter only works when a valid video signal is detected, which is why it's not advancing as the tape plays. There's nothing you can do to recover whatever was on the tape, so I hope it wasn't anything important.
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
You need to have the model number (DRC 8335) and the serial number before you call.
Apparently this model has had a lot of problems as they have set up this number specificaly for this model. They will ask you a few questions and then they will send you another unit. You will to pay to ship it yourself. You should read the reviews on Amazon.com.
As for geting your VHS Tape out ...Hopefully when they send you a new machine they can send your tape back with it...but dont count on it.
I work at the History Channel and have a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
The idler wheel (that only drives the tape in play or scan modes) is
slipping too much (very common problem). Try verify this by
putting the tape in play then immediately press the fast fwd or rewind
buttons to scan the tape. On older machines, the idlers used
rubber friction tires - on newer ones, a clutch. Either replace
the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
