Refrigerators Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a 3 yr old Haier Fridge serial #HBP18GAAWW, the feezer is on the bottom. The food and drinks keep freezing in the fridge and there is alot of frost in the freezer. Is there a problem with his model would it be the thermostat?
Anonymous
Level 3:
President:
  • Master 1,796 Answers
  • Posted on Aug 12, 2010
Anonymous
Master
Level 3:
President:
Answers
1796
Questions
0
Helped
840576
Points
5971
Have you tried to lower the temp.settings?? If settings are about 1/3 of the range, then it could be a thermostat problem.
Keep me posted!! Rate this post!!
  • jmccabe394 Aug 12, 2010
    Yes I have...Is there a problem with thermostats with this model?
  • Anonymous Aug 12, 2010
    I had two requests today for the same thing. That's something!!
    Could you remove the freezer back panel to check if the themostat's sensor is clipped to he evaporator colil?? Just need to turn unit off and unplugged from the wall.. The thermostat sensing unit is a skinny wire or tube clipped to the evaporator, you can't miss it.
    Check and let me know what you see
Fridge section keeps freezing up.
Hi,I had trubble with my fridge so done a bit of reserch the main reason for the fride freesing up is,
fridge not set at right temp (3 to 7 c ) or vent where water drains blocked,shelves not in right place as in manuel,and if you put veg that has alot of mosture content can also course freezing at the bottom of the fridge,hope this was some help,maybe buy a fermomiter to test.
MY HAIER 1.7 FRIDGE FREEZES ONLY
my trf 285 intergrated fridge freezer has same problem fridge is freezing our food have been informed that a valvue is stuck open the solution
offered was defrost and leave for 2 days i did that it did not work the valvue is not replaceable hope this is some help
The fridge section of the appliance is not automatically defrosting the fridge is on the lowest setting but still manages to freeze food and drinks solid
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
2helpful
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
3helpful
2answers
My fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Ed22pwxxn00 setting on 3 top shelf items freeze. Is our 18 yr old fridge going out?
Adjust the freezer damper to a higher number to reduce cold air flow to the fridge section. This will eliminate freezing in the fresh food section.
1helpful
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
1helpful
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
