20 Most Recent
Haier (492420265334) Refrigerator With Ice Box Questions & Answers
The freezer door has a slight gap at the top
Replace the gasket.
Your local appliance parts hose should have them in stock, and if not can likely order them.
This is a common problem and quite easy to fix. Most gaskets are simply pressed into a seam in the door. A few are held in place by simple metal brackets than can be removed with a screwdriver.
8/24/2009 1:54:53 AM •
Haier...
Answered
on Aug 24, 2009
My freezer fan is not working. Can it be fixed?
The fan won't work when the unit is in the defrost cycle.
Some won't run when the door is open.
It won't run when the compressor isn't running.
Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
And yes, you can replace it.
7/11/2009 10:11:03 PM •
Haier...
Answered
on Jul 11, 2009
Haier 4.6 stainless steel fridge...
Check the thermostat. make sure it is turned on. The thermostat can shut it off. Also check to see if you have power to that outlet you are using. If none of that is the problem you can try and bypass the thermostat with a jumper wire( If you are comfortable with do this) Be careful when doing this cause electric shock is possible. don't touch any wires directly
4/24/2009 3:20:23 PM •
Haier...
Answered
on Apr 24, 2009
Beko fridge freezer humming
- Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object.
1/12/2008 11:23:44 AM •
Haier...
Answered
on Jan 12, 2008
HAIER REFRIG IN A CAMPER
Interesting! I'm going to assume that this is a 110V unit running on an alternate power supply rather than regular AC. First: test the circuit with at least a 100 watt light bulb for a few minutes. If that looks okay (bulb at full brightness, not flickering), let's go on. What I also don't know is what 'overloads' you're speaking about. If it is the compressor (there is a light clicking sound periodically in or near the black compressor unit), the problem could be that it is overheating because something is blocking the airflow around the coils like an ant nest or debris. You've got to go in and clean them. Unplug unit, remove the contents and glass shelves, lay the unit on its side so you can see what's what in the back. Remove anything that looks like the manufacturer didn't put it in there. Look up into the area where the tubes go into the back panel area, too. Do not clean with water! If the unit is more than 5 years old, it probably should be scrapped. Note that older units have R-12 refrigerant which should be handled only by a qualified tech or recycler.
11/25/2007 8:43:43 PM •
Haier...
Answered
on Nov 25, 2007
Fan Not Coming On & Compressor Is Hot
Ckecked around for the fan, parts for this unit are few and far between did locate some on ebay so head over there. Cuz there were quite a few but without seeing yours I couldn't match up what I was seeing.
1/22/2023 3:49:52 PM •
Haier...
Answered
on Jan 22, 2023
My haier 10.5 model 10TG31SW is not cooling neither top or bottom any clues
If your Haier 10.5 model 10TG31SW refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can check:
- Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
- Check the condenser coils: The condenser coils may be dirty or clogged, preventing the refrigerator from cooling properly. Clean the coils with a brush or vacuum.
- Check the door seal: Make sure the door seal is tight and not damaged. If the seal is not tight, cold air will escape and the refrigerator will not cool properly.
- Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the refrigerator not to cool.
- Check the compressor: If the compressor is not functioning properly, the refrigerator will not cool. It may need to be replaced by a professional.
- Check the refrigerant level: If the refrigerant level is low, it can cause the cooling system to fail. This is a job that should be done by a professional with the right equipment and experience.
- Check the defrost system: If the defrost system is not working properly, the evaporator coils will frost over and the refrigeration will not work.
- Check the power supply: Make sure the fridge is properly plugged in and that the outlet has power.
Please note that it's also possible that there could be other issues causing your refrigerator not to cool, so it may be best to seek the help of a professional if the above steps do not resolve the problem.
1/22/2023 3:20:45 PM •
Haier...
Answered
on Jan 22, 2023
Is there any way I can delete the alarm beep when doors are left open on my new Haier fridge HSBS610IS please?
It depends on the model of your Haier refrigerator. Many newer models of Haier refrigerators have a feature to disable the alarm beep when the doors are left open. To disable the alarm beep, you will need to check the user manual of your refrigerator for specific instructions on how to do this, as the process may vary depending on the model.
Here are a few general steps that could help you to disable the alarm beep:
- Look for a button or switch labeled "alarm" or "door alarm" on the control panel of your refrigerator.
- Press and hold the button or switch for a few seconds until the alarm stops beeping. This should disable the door alarm.
- In some models, you can disable it through the settings menu of the control panel, look for the alarm setting and turn it off.
- Look for the manual of your refrigerator, it should have the information on how to do it.
If you can't find a way to disable the alarm beep, or you are not comfortable with following the instructions, it's best to contact the manufacturer or a professional for further assistance.
1/22/2023 3:18:34 PM •
Haier...
Answered
on Jan 22, 2023
