Elder parents have a 1 1/2 yr old HP Pavillion Series 4600. They are getting a black screen that reads "Disc Boot Failure Code HP-BIOHD2. Can you help me?
Do you mean the hard drive or the hard disk that "should've" come with the computer?Do you mean the hard drive or the hard disk that "should've" come with the computer?
You can't post conmments that contain an email address.
Hard drive is the older name of the hard disk and yes, it has died and must be replaced. You are probably referring to the recovery disk that must be obtained from HP to be used to reinstall Windows.
DELL BEEP CODES Beep CodesBeep CodeDescriptionFailure Coverage 1 System Board: BIOS ROM failure System Board, covers
BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error
(North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform);
Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate
A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM
Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video
BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure
8 LCD LCD failure
goto your computer company's website for e.g. if you have a hp pavillion goto hp.com downloads and support and look for recovery discs. youll have two options you can either download it from the website and make a copy or you can have one delivered. once you have the disc iinsert and restart. youll see a black screen reading press any key to boot from cd. press a key and follow the steps.
if i'm reading this correctly, it sounds like it could be a motherboard/video issue. If that's the case then unfortunately you are probably going to need a new computer if it's out of warranty...
for now however, try shutting down the computer and removing all power (power cord, battery) for a few minutes, then plug it back in and try to boot.
