Take a hair dryer a thaw out section behind the water outlet these units are junk.
Might just be a bad solenoid on your water valve. These are multiple valves that use separate solenoids. The solenoid for water in the door might be bad. Here is your MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Most likely you water solenoid is bad. need to make sure you get voltage(120v) to water solenoid. if voltage then the only other thing that could be wrong besides the solenoid. would be a kinked hose or the line (has a small chance) has frooze inside the door panel if sprung a leak.
