I didn't think the hinge was on the door, it is usually on the oven and the door just slips down on it, and the door becomes the lever to work the pressure of the hinge. Did you get the door off yet? Just open it to the first rest, and pull up on it, it should come right off, the spring loaded hinges are on the oven like a mousetrap. Don't get you fingers in the way. They are hard to open with no door in place, but it can be done. Slide the door back on the hinges, you should be all set. I hope this is what you got going there.
Hello. Typically, the hinge is attached to the frame of the oven opening and then opened 1/4 or so [preloaded]. J.
Ovens
come in many varieties including freestanding units and stacked models
that are inserted into a wall. Kitchen oven units that get a lot of use
or are getting old may have problems develop, such as a loose or
squeaky door which may require replacing the hinges. You can replace
the hinges on the door to your oven by first removing the door from the
rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Difficulty: Moderate
Instructions
Things You'll Need:
Regards
Iversh
Follow the procedure below,
Open the oven door and grasp the sides with one hand on each side. Lift
the door up to remove it from the hinges. Set the door out of the way.
Remove the range top by unscrewing the attaching bolt on the front door
flange with a socket wrench. The screws are located in the upper
corners, where the door closes.
Slide the top of the range forward about 6 inches from the control
panel. Locate the wiring harness from the range top to the control
panel. Disconnect it by pushing in on the plastic tab and pulling it
apart. Grasp the top panel with both hands and lift it from the stove.
Set it aside in a safe place.
Remove the screws on the rear edge of each side panel that connects the
side to the rear of the stove. Also remove the screw on each end cap of
the control with a screwdriver. Lift the side panel up, removing it
from the key hole tabs on the front, and set to the side.
Remove the two hex head screws that attach the hinge to the front of the
oven using a socket wrench. They are located above and below the hinge.
Install the new hinges by attaching them with the hex head screws.
Line up the side panel with the front panel key hole and set it in
place. Attach the side panel to the rear of the stove with the attaching
screws and reattach the console ends with a single screw on each side.
Place the top panel back on the oven. Connect the control panel wires to
the range top by pushing the connector back together. Slide the top
panel back into position.
Secure the top panel by reattaching the screws under the front flange.
Open the ends of the hinges with your finger at about a 45 degree angle.
Set the door in the hinges and close the door.
Reconnect the power to the range and slide the range back into its
position.
Take care.
Thermador sc301: I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Thermador sc301: have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door? I have asked this question 3 times and each answer is clearly a generic response.
