Porcher 6.0 Lpf / 1.6 gpf toilet. Plumber said he didn't like the model and would recommend replacing toilet??? Valve leaks water into bowl causing frequent refilling of tank. Help?
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
