20 Most Recent Porcher Toilet Seat Veneto 70032.001 Questions & Answers
2answers
How do i take the lid of the cistern
There is a trick to this for Porcher toilets. Push big flush button down, then lift up and out the small button. The big button lifts out. Undo plastic bolt and lift up lid. cheers, zoofish
9/13/2015 2:50:54 AM • Porcher Toilet... • Answered on Sep 13, 2015
Where can I purchase this item?
Most hardware stores will get it for you if they don't have it in stock.
3/13/2015 4:33:32 AM • Porcher Toilet... • Answered on Mar 13, 2015
0answers
Porcher Toilet Lid Hinges are loose
Hello,Tinkerbellpp is right about the 70032-00.001being out of stock. You can replace this with the 70030-00.001(chrome hinges) seat which will fit the Veneto Toilet. You can find this at your local dealer/showroom. Hope that helps!
1/8/2013 6:36:24 PM • Porcher Toilet... • Answered on Jan 08, 2013
Not sure how to tighten
First you want to reach underneath your toilet where the seat connects to it. You should see some sort of white nut. Just unscrew the nut from both sides. Once you're done with that pull off the old seat and place the new one on. Use the new nuts to tighten it down. For the most part you should be able to use your hand and not need any tools.
4/18/2011 12:36:47 AM • Porcher Toilet... • Answered on Apr 18, 2011
2answers
Slow close feature on seat
Hello wkere.... you will need to replace the self-closure mechanisms. Here is a link to the Porcher company customer service.
http://www.porcher-us.com/contact.aspx
Joe
Thanks for choosing Fixya!
1/27/2011 4:52:57 PM • Porcher Toilet... • Answered on Jan 27, 2011
I have a biscuit one piece toilet and can not find
try fergusons plumbing supply
12/6/2010 2:40:31 AM • Porcher Toilet... • Answered on Dec 06, 2010
2answers
Where can I find a replacement parts to rebuild a porcher Veneto one piece toilet
http://www.porcher-us.com/assets/documents/porcher/spec/SpecSheet_3362.pdf http://www.guillens.com/POR/9712.htm Parts breakdown. Specs are above. Immediately below is the company site but they may only offer some support rather than directly providing any parts. I list a couple of possible sources for parts after that. Welcome to Porcher http://www.guillens.com/buy/product/97120-00-001/22791 Porcher Faucet Toilet Parts
5/14/2022 9:00:52 PM • Porcher Home • Answered on May 14, 2022
2answers
My Porcher Calla toilet hinge nuts have broken. They are plastic. I cannot find replacements for the nuts. The inside diameter of the nuts is between 3/16 and 1/4.
It may be possible to replace the cheap plastic hardware with real metal hardware. Back in the day, hardware was brass.
11/21/2020 2:10:14 AM • Porcher Home • Answered on Nov 21, 2020
I have a porcher cygnet toilet I need to replace the flushing mechanism, how do I do it
https://www.youtube.com/watch?v=FlJ3UQlkEdU First you will need to obtain the kit or parts necessary for replacement, compare your parts to your existing before doing anything, you will need your model number and if you had a picture more help could be offered. Begin by turning off the water supply to the toilet, keep a small bucket handy to catch the water, disconnect the supply line at the toilet if your are doing a complete replacement. If its only the handle again a handle kit will need to be obtained for your specific model no need to turn off water but keep in mind your exact handle or button placement. When you have the correct parts its just a matter of remove and replace and take photos of before so you can reference what goes where if you get sidetracked.
11/11/2018 7:41:08 PM • Porcher Home • Answered on Nov 11, 2018
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
2/20/2018 9:55:03 AM • Porcher Home • Answered on Feb 20, 2018
0answers
Porcher Toilet Seat  Veneto  70032.001 Logo
19 questions posted
Top Porcher Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Porcher Home Expert? Answer questions, earn points and help others
View Most Popular
Porcher Home
  • Porcher Home
Most Popular Question
lid cistern
  • Home
