Motorola Mobility H3 Bluetooth Headset, Black Headset Logo
Posted on Jul 12, 2010
I want to use my Motorolla Universal Bluetooth to my phone 3110c
I want to use my Motorolla Universal Bluetooth headset to my Nokia 3110c phone but I do not know the passcode in my phone
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Jul 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
3621
Points
32
If you are speaking about the 'Bluetooth Passcode" it's either 1234 or it's 0000 (That's 4 zeros or zeds, eh?)
RAy
MY NOKIA E72 CANNOT CONNECT WITH HEADSET
Have a cell phone that is Bluetooth compatible. You can check your cell phone to make sure that it is Bluetooth compatible by looking in the settings. There should be an option for Bluetooth listed. Click on it and ensure that it is set to "Allow other Bluetooth devices to find me."
Read morCONTINUED HERE
http://www.ehow.com/how_2153950_setup-bluetooth-headset-work-cell.html
1helpful
2answers
I have a motorola HT820 Bluetooth stereo headphone. And I want to pair it with my Nokia 3110c. But every time I search for the paring device it shows no result. How can I pair my headphone with my nokia...
Make sure your headphones are turned off. Hold call button for 6 seconds, until you see the light steadily lit. Now pair with your phone: Motorola HT820, and type passkey: 0000. Done!
5helpful
3110c restart
saya tak bisa menemukan kode pengaman yang diperlukan untuk merestart nokia 3110c
2answers
Okia 3110c i cannot receive any files from
blue tooth IC is malfunctioning u will need to replace it. Also check if u can send through bluetooth if u can then u need to dump all items into folders and then check
Can't connect
0000 is the universal code for almost all bluetooth sets.
3helpful
Blue tooth headset for nokia 3110c
You can purchase a universal bluetooth headset and then pair the device using the instruction manual that comes with the headset. This is a very easy process and all you need to do is make sure that the blutooth on your phone is switched on. When you turn the headset on, it should automatically pair after the first attempt.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
