I've charged it for an hour and when I start to use it for awhile it stops and needs to be charged again. This has occurred many times. Also, the red light that usually comes on when it's charging doesn't light up anymore. I'm guessing there's something wrong with either the extension or the epilator itself.
SOURCE: Trimmer Not Charging - No CHARGE Light too.
I had the same problem, I suggest that you go to your local WAL-MART and return it. Just tell them you want to exchange with a different one and forgot the receipt. This works because I did it with my Remington MB 300 Beard Trimmer.
SOURCE: remington epilator is not getting
You likely need to replace the battery. This needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
SOURCE: My remington epilator -model EP6025-
I'm having the same problem right now, but I tried using my grandmom's phone charger adapter and it works even though the charging indicator light didnt turn on still, so I'm guessing you should just find a new charger see if it works. let me know if its a new charger that we need.. thanks
