For clarification, may I know how long that your computer before it going to sleep mode?
You can change the settings on how the computer hibernate or gone to sleep mode by going to display properties >> click on the screen saver tab >> clcik on the Power button. There you can set the time on how long the computer will gone to sleep.
Called 'Sleep Mode', it saves your battery and screen.
To turn off sleep mode on a Mac, go to System Preferences > Energy Saver. Then tick the box next to Prevent computer from sleeping automatically when the display is off and drag the Turn display off after slider to Never.
Dec 24, 2021
Hey Robyn,.. not sure which O/S you are using... go to Control Panel, click on Hardware and Sound, click on Power Options, click/select on High Performance... click next...you will now have the option to set when to : dim the display, when to turn off the display, and WHEN to put the computer to sleep.. ---- I set mine to NEVER!.... save and close
Your settings in power mode have changed. Open up display and go to the screen saver tab (win 7) you will see the power savings option at the bottom. Go into that and change what the buttons do. You will have 3 situations to change. What happens when i close the lid, power button and sleep mode. Chances are you gave everything set to do nothing
Take out the red safety stop key, hold down the "start", "stop" and "Enter" buttons, keep holding them down while putting the red key back in (a bit tricky), keep holding the keys down until you see "Maintenance menu" scrolling (this will happen as long as you didn't let go of the three keys).
Initially when you put the red key in it'll might show software version etc, after a few seconds it'll change to maintenance menu. Use the speed UP and Down buttons on the console or arm to scroll through menu until you reach "FUNCTIONS" press enter.
In the functions sub-menu, depending on what year model/software version it has, it should have a selection called "Sleep Timer" if so set it using up down keys to "ON". If your model doesn't have "sleep timer" listed (i.e. a newer model) it's now just called "DISPLAY" and in that case set it to "OFF". That should fix it.
Press Stop, to go back. If you want you can disable the key tone/training beeping as well in the "functions" sub-menu of the "maintenance menu".
To exit press stop repeatedly until you're back to the normal display.
when pc starts hit alt and f4 then select an option from drop down menu by cliking on little v sign on right of box the option that should be there is sleep select shutdown then reboot it might work if not try same steps in safety mode by pressing f8 on first screen when pc starts select safety mode then try those steps again might help
I FIX LOTS OF COMPUTER, AND MY ADVISE IS. IT MIGHT BE YOUR COMPUTERS VIDEO CARD CAUSING THAT PROBLEM . ALSO CHECK FOR VIRUSES THEY CAN DO STRANGE THINGS.
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
