Hotpoint Ultima WF860 Front Load Washer Logo
Posted on Apr 07, 2008
Tumble dryer not drying
Hi my tumble dryer wont dry. it gets luke warm on some settings and stays cold on other settings . could it be the sensors on the drum or the thermostat or something else ?  can anyone help please
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Apr 13, 2008
Anonymous
Contributor
Level 1:
Answers
32
Questions
Helped
23767
Points
65
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
Dryer heats on sensor programs, but just luke warm on timed programs,.
THE TIMES DRY USES THE MOISTER SENSOR WHEREAS THE AUTO DRY DOES NOT SO i WOULD CHECK THE MOISTER SENSOR OUT WITH A METER AND CHECK UR VENTING SYSTEM AS WELL, BLOWER OBSTRUCTION ETC
Feb 15, 2015 • Dryers
1helpful
Tumble dry wont turn and dry
check that your motor spins and your belt is on the drum. you say its heating so your door switch isn't the problem.
May 30, 2014 • Cell Phones
Hotpoint WDF740G Dryer not Very Hot
Most likely to be either that the capacitor is defective which starts the motor slowly at first and then picks up speed or the drive belt is worn, usually this happens when the drum has clothes in it otherwise it looks as if it is operating normally
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 • Dryers
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
1helpful
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Cdc266 tumble dryer
hi you have to clean the inside of the machine I.E. remove the drum and on the back of the machine there are two heat sensors, the ceramic sensor is possibly faulty and needs replaceing
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 • Dryers
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
