Try this:
Swith off the copier (with the switch inside the copier)
push the button (utiliy/counter and stay pushed while you switch on the copier (general and second on/off button).
Check the screen while you stay pushing the utility/counter button, and you'll see the black dot .... just wait, a new screen will appera, with the mention 'trouble reset". push it , and the restart the copier with the general on/off button. BUT, if the fixing unit is out of order, the error code will aappear one more time, unless you'll change the unit ...
This is a fusing pressure roller code.....
The way to clear the code is by opening/closing the front door.
This is the way to clear the code in the service manuel....so it is appropriate....If you can not clear the error code is that you have a problem in your fusing section....maybe a bad sensor, a little bit of paper that stuck in it.... ! When you open and close the front door, check if you do not see a little black dot in the left middle side of your screen....if you do, press it and a new window will appear and let you choose front different thing....press reset error code....let me know !
this doesn't work, we do not see a little black dot in the left middle side of your screen. Please help!
Vikki
I have the same problem. I've opened the front cover, and cleared all jams. There is no "dot", for me to go into another screen. My suspicion is that, either the sensor to the fuser is bad, or the fuser itself is bad. Is that a possibility?
Thank you,
Kenny
[email protected]
