Uniden Cordless Phone Logo
Posted on Apr 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Callers cannot hear me speak....I can hear them, but they can't hear me!!!
Anonymous
Level 3:
President:
  • Master 1,561 Answers
  • Posted on Apr 14, 2010
Anonymous
Master
Level 3:
President:
Answers
1561
Questions
0
Helped
296550
Points
4482
Since you can hear them but they cannot hear you, the problem is your mouth piece.
All you need to do is to change your mouth piece,because it is now bad.
Meanwhile, i advice you get hands free,before you fix your mouth piece problem. this will help when you call, the callers will be able to her you with the hands free and you can also hear when people call you.
Take care.
My tecno t340 mic is not working
i have the same proplem..my callers cant hear me but i can hear them perfectly. iam using tecno h6 .please help me with a solution.
Jan 21, 2014 • Cell Phones
My callers cannot hear me
Check to see if you have it on mute. Go into your menu options and under sound hit ok It should show master volume, keypad, earpiece,speaker try master volume then volume up .
Callers to my phone cannot hear me speaking.I can hear them
If callers cant hear you when you speak to them on your phone,it means that your phones mouth piece is bad and you need to replace it and to do that you need to take it to phone repair shop.
You can also try using an external ear piece attached to the phone to make and receive calls before you fix the phone.
I hope this helps you. contact me for more help.
1helpful
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
7helpful
Cannot hear callers voice during a call but caller hears mine
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear speaker.you can do your self just watch video on online.
How do you record outgoing message?
RECORD AN ANNOUNCEMENT
1 Prepare your announcement. Each
announcement can be up to 4 minutes long.
2 Press A.
3 Press and release S until you see
the letter of the announcement you want
to record (A, B, or O).
4 Press R. Begin speaking after you
hear the beep. Speak in a normal tone
of voice, about 9 inches from the
microphone.
5 Press S. The system plays your new
announcement. To hear the announcement
again, press P.
6 Repeat Steps 3 to 5 to record another
announcement, or press S.
To assign an announcement to play:
SELECT ANNOUNCEMENT CALLERS HEAR
1 Press and release F until the screen
displays ANNC.
2 Press and release S until the screen
displays the announcement you want
callers to hear (A, B, or O). If you
select AO, you must record an announcement,
as instructed in “Record an
Announcement.”
3 Press S to return to the message display
Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
yah.... your mouthpiece might be distorted...
go to the nearest sevice center and ask them to replace the mouth piece.....or microphone either....
sexy-ym
1helpful
Callers say they cannot hear me
Yes it very well could be your phone lines and not the system. Call your provider and tell them you have low speech path on your lines. They will troublshoot it.
Callers cannot hear me when I am talking to them.
try with ur handsfree that u got with phone or replce ur mic or clean the hole near ur swich side from where u speak. reply me
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
