20 Most Recent Samsung C417 Cellular Phone Questions & Answers
manual
I recieved a text message,
I had "Memory full" on my SGH-C417 and first had cleaned all text messages - did not help. Next step was to check myMemory status in my Stuff. It shows free memory size and size of graphic data in your memory. I my case, free memory size was 0 and graphic data took all available memory. To resove the issue I went to Graphics in My Stuff and cleaned a lot of empty pictures - SGH may take a picture in your pockect, just because photo button, located on back side of phone, been hit by something, you put in your pocket.
try it!
9/17/2011 9:20:16 PM • Samsung C417... • Answered on Sep 17, 2011
2answers
Deblocague de mon samsung
There are many methods for unlocking mobile phones, that is through software, codes,calculator,some tools , hardware and all ,but in that codes are best one,because it is easy to understand the instructions and enter into your mobile ,just give your IMEI number, country & network lock ,then you can get the unlock code..........
For the good place to get the unlock code for your mobile phone, Just visit this site www.mobile-unlocker.com/samsung-m310/rs2wp9 , It provides the step by step instructions and simple methods for unlocking mobile phones at a safe way.......After you unlock your phone, you can use it with any other network's sim card.
8/10/2011 11:33:21 PM • Samsung C417... • Answered on Aug 10, 2011
Insert sim samsung c417
Hi
take out your cart and putt it again in
this will fix it
12/18/2010 12:17:49 PM • Samsung C417... • Answered on Dec 18, 2010
Can't remember password,phone is locked
To Unlock the Nokia from the Security Lock You can use the Master Reset Code.,You can get the Master reset code at Reliable cost at
http://www.onlinegsmunlock.com/unlocking-services/rs7wp6/ and Unlock it.Check Master Reset Code for Your Brand and Model....
11/25/2010 11:03:39 AM • Samsung C417... • Answered on Nov 25, 2010
Persons on the other end of a call cannot hear why
your mike may not be working so go to samsung customer care centre
9/12/2010 6:43:03 PM • Samsung C417... • Answered on Sep 12, 2010
Unlocking samsung c417
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Hope this helps, feel free to leave apositive rating if this works for you.Thank you for stopping by Fixya!
3/27/2010 10:59:50 PM • Samsung C417... • Answered on Mar 27, 2010
Would like to get an instruction manual for
http://www.manualnguide.com/dl/951/
this is the direct link to your manual in pdf format...i hope this is what u were lukn for...
cheersss...pls rate...
1/4/2010 3:36:19 PM • Samsung C417... • Answered on Jan 04, 2010
My blackberry arrived in the post and the screen
Complain and return it if possible. It will cost quite a bit to repair.
10/17/2009 4:40:53 PM • Samsung C417... • Answered on Oct 17, 2009
2answers
My C417 Samsung phone has recently had problems
The issue is, The phone freezes and it makes your number as not reachable, since the mobile loses the signal and freezes up..
You must have set to divert calls to Voice mail, if not reachable..So immediately after the phone freezing up, your calls are diverted to voice mail..
These are all the issues, faced by every user who uses the Samsung c417, You can read the review from the following link below
http://www.phonescoop.com/phones/user_reviews.php?phone=1030
The only solution is updating the phone firmware, The new firmware must be made to remove this known issues..
Try updating the firmware, would solve your issues.
Please leave me comment, if you need furthur assistance
RNJ VINODKUMAR
9/28/2009 6:45:43 PM • Samsung C417... • Answered on Sep 28, 2009
7answers
Can you please provide me with the PUK code for my phone please?
try PUK code 05607773 then make your new pin code
9/19/2009 7:55:00 AM • Samsung C417... • Answered on Sep 19, 2009
Phone Restarting
Hi Friend,
The only solution u can do is as follows,
Initially switch off the mobile and then remove the battery and the sim card also
After 30 Sec u replace all the things in the mobile
Restart the mobile after 10 to 15 sec and then check it out,u wont get the problem again.
Regards,
Ayyasam
5/30/2009 8:47:48 PM • Samsung C417... • Answered on May 30, 2009
Memory card isnt recgognised!
If the card is inserted correctly and its not damaged, then the memory card should show up under media manager, you need to put the files onto the memory card not on the phone...
When you first insert the card into the phone, you need to format the card, some phones create specific folders for different things when they format, e,g images, Videos, etc. You may need to do this.
I cant remember if this phone had this option but try it anyway as if it works, it should be faster than using Samsung PC Studio...
Close Samsung PC Studio
Unplug USB out of the Phone and a couple of seconds later plug it back in, see if the phone asks you for Mass Storage mode... If it does select that, after a while the Memory Card should show up on your PC just like a USB memory stick you can drag and drop files to it and its faster than going through Samsung PC Studio :)
5/23/2009 5:04:30 PM • Samsung C417... • Answered on May 23, 2009
Samsung SGH-C417 Keypad will not work
5/18/2009 10:37:51 AM • Samsung C417... • Answered on May 18, 2009
Our SGH-c417 Samsung cell phone will pair easily
I have had a similar issue with SGH-A707, I have found that taking the device out of discover mode, then removing the battery from the phone to reboot it. once booted, turn on the bluetooth on the phone and put the device into discover mode. Should find it.
3/20/2009 8:01:52 PM • Samsung C417... • Answered on Mar 20, 2009
Cant dial
the keyboard needs to be replaced or service, so take the phone to a mobile service center to have it fixed.
12/24/2008 3:27:10 AM • Samsung C417... • Answered on Dec 24, 2008
Forgetten security code.
do a hard reset press *2767*3855#
12/24/2008 3:22:39 AM • Samsung C417... • Answered on Dec 24, 2008
Phone goes out intermittenly.
do a hard reset *2767*3855#
12/24/2008 3:21:49 AM • Samsung C417... • Answered on Dec 24, 2008
Samsung C417 Cellular Phone Logo
Popular Tags
77 questions posted
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
deblocague de mon samsung
  • Cell Phones
