Check all fluid levels, engine, transmission, differentials, etc, also do a complete look over the machine to see it something is not jammed up! Have someone drive it forward or backwards, while your standing beside it and narrow down where the noise is coming from. And go from there.
i was told its in the parking brake switch you have to unplug it uner the boot if that dont work try relay fuse i have the same problem and buzzer is on
the screeching sound could be a belt slipping. there should be a neutral adjusment on the valves that the sticks are attached to. its just a matter of finding true neutral.
Pregunta , tienes, el manual de la case 580 ck, donde se muestra el circuito hidrailico de la transmision, si es asi, embiame una foto del circuito o el manual y te puedo apoyar.
