20 Most Recent
Jcb Bruder JCB Loader Backhoe Questions & Answers
How do I tilt the cab back to get access to the pipes under my JCB 2007 8014
Yes it tilts to about 20 degrees.
At the front on the cab / canopy is two large mouting bolts. You undo these but first you need to sort out the aux pedals and the dirt cover that goes over them.
I think thats some hex bolts. Once that is off you can unclip the pedals and then undo the main bolts and the cab will hinge backwards.
Its a one man job until you need to put it back down as you need to relocate the slew lock.
You may have to unclip the tracking levers in the middle of all of that but there only on small clips so its easy to do.
The hinge locks in place so you will have to unclip it for it to return back down.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
8014 8016 Conventional Tail Swing Mini Excavator DirectIndustry
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
