SOURCE: Natural gas to propane
GE is one company which generally includes all necessary parts and instructions for conversion to LP with the range without having to order or purchase anything extra. Check the mini manual in the white envelope pasted to the back of the range for instructions. Generally, the LP orifices are in a metal holder near the gas regulator (right where the gas connects to the range). You will have to flip the plunger in the center of the regulator and turn down the collar (with a 1/2 inch open end wrench) on the oven burner and broil burner about 3 full turns. Air shutters are usually OK without any adjustments.
SOURCE: Users Manual RGA520 EW2
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=RGA520EWWH
SOURCE: how to convert a natural
You can find the information you need at the web site below:
You will need a conversion kit, which you can order from them if you like. They also offer instructions on converting to propane.
http://www.applianceaid.com/gas_range_convertion.html
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
Do not use the stove until its properly converted back to natural gas. It's a serious carbon monoxide hazard.
Most ppl throw the orifices away, sometimes they are stored under the stovetop in the back, or behind it. The original natural gas orifices are the only parts you need. All orifices are labeled by a tiny stamp on the side. It will state the size and type, example: 10 LP.....meaning number 10 size and propane.
A nature gas should be labeled something like 12 NG.
Call a local parts dealer or order online the NG orifices for you model number.
I assume you do not have the setup instrctions that come new with the unit. Heres what you need to do:
1) Change the orifies to NG (the bigger the burner the higher the size number) so if you have two #10 size, one #12 and one #14...then common sence will tell you where they go.
2) convert the regulator. This is the part to which the inlet connects.
Remove the vent cap,(a plastic cap, you'll see it) unscrew and flip the insert over and
reinsert it
(You'll usually see 'NAT' on one side and 'LP' on the
other). Reinstall
the cap, and that's done. The word NAT should be facing you where you can read it.
3) Then,
find the brass orifice that supplies the bake burner (usually under
the range, behind the drawer), and if included, the broil burner
(usually inside the oven). These are adjustable, and, like adjustable
top burners, are simply 'snugged' down clockwise with a
1/2 inch wrench. You need to screw these back up for natural Gas.
You know when the oven is correct, you should get a nice blue flame on top as well as in the oven. Flames with yellow tips are wrong!
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
