SOURCE: whirlpool duet front load
In many cases these error codes can be erroneous. If you reset the Central Control Unit (the Main Control for the washer), in many cases, the problem will clear. You must unplug the washer for AT LEAST 30 minutes in order to do this, however. If an error code returns following a CCU reset, then you have a legitimate problem.
SOURCE: Having problems with washer. every time i wash,
That is when the spin cycle starts I believe. Might want to check the motor coupling to see if its broke
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
