20 Most Recent Whirlpool GHW9150 Duet Washer Questions & Answers
Whirlpool duet washer fabric softener dispenser does not empty
Hi thereI wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.I hope it workskolbrun
3/21/2015 11:42:12 PM • Whirlpool... • Answered on Mar 21, 2015
2answers
Duet HT front loaded washer GHW9250ML1 Type 199 080 SC/WG 1. ... rusting basin The inside basin of my washing machine is rusting, leaving rust stains on
it must be old , probably the rubber seal need sealing , clean and seal with silacon
4/18/2014 12:45:07 PM • Whirlpool... • Answered on Apr 18, 2014
Too much water going to the tub
Many top load machines have a big metal water level sensor up in the electronics bank with a plastic tube that senses pressure as it fills. There is a small half inch screw in the center of it that is adjustable to set the water level on that thing. The sensor sort of looks like a car EGR vacuum recycler valve. Check Google images of washing machine water level sensors to see if your has it, as it is fairly universal. Make sure your pressure tube is not loose or kinked.
3/12/2014 6:59:21 AM • Whirlpool... • Answered on Mar 12, 2014
What does F02 mean
water pump
1/22/2014 12:06:39 AM • Whirlpool... • Answered on Jan 22, 2014
0answers
Code s11
Be the first to answer 1/13/2014 12:53:48 AM • Whirlpool... • Posted on Jan 13, 2014Be the first to answer
I have a whirpool duet front loader washe. This washer is about 3 years old and we did'nt use for a year. When we moved to different place and start using the washer there's something wrong going on.
See if the machine will fill up and pump out water. If it does then check the drive belt and brushes on the motor. Hope this helps
11/27/2013 8:35:05 PM • Whirlpool... • Answered on Nov 27, 2013
Whirlpool duet front load washer with F 06 error
could be control board, in the past this has been an expensive error code to diagnose
11/3/2013 5:40:48 PM • Whirlpool... • Answered on Nov 03, 2013
2answers
Whirlpool duet front load washer banging Loudly during spin cycle as if off balance
More than likely the washer tub bearing is worn out, this happens due to seal failure and soapy water getting into the bearing, the soap is very corrosive and the bearing fails quickly, this in turn destroys the drum vibration dampers and makes it much worse. The cost to repair this is about $400
10/7/2013 7:22:28 PM • Whirlpool... • Answered on Oct 07, 2013
Does not rinse
see the cause and fix it. God bless youf the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
9/23/2012 4:49:06 AM • Whirlpool... • Answered on Sep 23, 2012
0answers
GHW9150 will not start, door
This means that the CCU on the rear of the washer has an electronic glitch. Try unplugging the washer for several minutes if this does not work the CCU would need to be replaced.
To do so remove the top of the washer. Three screws hold it down. The ccu is on the top of the washer. Remove the wires and place on new.
Let me know
7/5/2012 1:25:58 AM • Whirlpool... • Answered on Jul 05, 2012
Washing Machines Logo
89 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
duet Whirlpool
  • duet Whirlpool
Most Popular Question
not rinse
  • Washing Machines
