Televison & Video Logo
Posted on Mar 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control programming - Televison & Video
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 114 Answers
  • Posted on Mar 13, 2008
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
114
Questions
0
Helped
48189
Points
208
Errr... that's just 2 words on a generic subject!? Are you having a problem? Asking for information? Looking for work? Typing random words in to forums? ;)
Seriously specifics help us to help you. :)
How to remote program control with Sony receiver and code to Sony receiver strawberry- deliver 575
Not sure where delivering 575 Strawberries came from, but I fixed your question a bit, even though I understand none of it!
Program a Remote Control ' Sony Canada
https://www.sony.ca > televisions-projectors > articles
Sep. 2, 2020 - For a complete list of remote control codes and programming ... You'll need the remote control model number to find the appropriate codes ... Can the Remote Control be Programmed to Operate a DVD/VCR or DVD/Receiver ... Missing: strawberry ‎' Must include: strawberry
Sony Remote Codes and Programming Instructions
https://www.directutor.com > content > sony-universal-r...
Programming Instructions, Follow these steps to program the remote control. 1. ... Universal remote control codes for SONY TV ... DBS Receiver Code Numbers: Missing: strawberry ‎' Must include: strawberry
2answers
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
How to program a whirlpool W10503278 control board
Programming Procedure:
The replacement control board is not programmed The Refrigerator will not operate without a code selected. It is important to program the control board with the correct code. Product must be powered up to program. If no code has been programmed the display will display 00 or flashing 00.
Note: The program code for this refrigerator is located on the serial plate on this unit after the word Code.
1. Open the fresh food door and hold the fresh food door light switch closed while pushing the freezer temperature down key pad 3 times consecutively.
2. Release the Fresh Food door light switch.
3. The control will display PE to confirm entry into the programming mode.
4. Entry is confirmed by pressing the Freezer Down key once more.
5. The control will display no Program Code.
6. To set the desired Program Code number, press the Freezer and Refrigerator UP keys. The corresponding digit will be advanced with each key press.
7. Once the desired Program Code is displayed, press the Freezer DOWN Key until the Program Code begins flashing indicating it has been saved.
Note: If you attempt to enter an invalid Program Code the control will not save the code, but will flash Program Code 00, (The unit will NOT run with a Program Code of 00).
8. Once the Program Code has been saved the Programming Mode is exited by closing the Refrigerator door(s).
Note: If you to enter a wrong Program Code the control can be reprogrammed by restarting the procedure from the beginning.
1helpful
2answers
9helpful
Where is the re-set button to program a remote door lock for my 2000 Subaru Forester?
Obtain all keys/remote controls. Remove driver's side kick panel/lower 'A' pillar trim. Connect central locking registration connectors (white) - black wire and black/blue wire Fig. 2 . Unlock the vehicle using the key. Program first key/remote control as follows: Press unlock button Fig. 1 [1], then lock button [2]. The door lock should lock and unlock in sequence confirming programming of first key/remote control. Repeat programming procedure for remaining key(s)/remote control(s). Once the last key/remote control is programmed disconnect central locking registration connectors. Check operation of all programmed keys/remote controls.
2answers
I'm trying to program my sansui tv with my universal remote
Instructions for programming your RCR311B can be found here ...
http://audiovox2.info/docs/rca_acc/man/RCR311BN_DOC_OM.PDF
1helpful
2answers
New alarm fob for pt cruiser not coded to car (correct serial numbers)
Programming
When
Remote control added or replaced. System malfunction.
How
Switch ignition ON. Press and hold lock button Fig. 1 [2] for approximately 10 seconds. Keeping lock button depressed, press and hold unlock button within 10 seconds. Programming mode activated (acoustic signal will be heard). Proceed as follows: Release lock/unlock button. Complete the following within 30 seconds: Press lock or unlock button of first remote control. Correct programming indicated by a single acoustic signal. Press lock or unlock button of second remote control. Correct programming indicated by a single acoustic signal. Repeat above procedure to program any remaining remote controls. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 remote controls can be programmed.
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
