Make sure all your connections are tight and you have power to your speakers...Then go Start>Control Panel>Sound and Hardware>Sound, after you are in here make sure that your speakers are selected as default device.
Hope this helps, pls rate
Hello Chaviva, monitor speakers is powered by a separate amplifier, independently, to check, if the amplifier is working, place your ear, close to the speakers, and adjust the volume control, you should hear a humming or hissing sound going up or down as you adjust the volume level (This is normal operation), if you cannot hear any noise or hum, problem with your amplifier. need to replace the IC. If you hear the volume going up or down as you adjust the volume level, check your wires and lines. from the source to the monitor sound input.
