On Off switch is the slide button on the side The switch may be faulty. You don't normally need it switched on to use USB, as the computer is supplying the power. This says it needs to be on for charging, that is odd!
Battery
3. Remarks (Additional information for Adaptor purchase)
2.1 Make sure the power switch is on to charge, or the player
could not be charged properly. The LED light 2 and LED light 1
are on when the player is charging, the light 1 will be off when
the battery is full
3.1 The adaptor must be conformed to following standard
the battery is full
2.2 Disconnect the player and charger if you want to stop charging
3.1.2 Output: 5.2V 0.2V
3.1.3 Max.: 350mA
3.1.4 4 pins adaptor
When connecting to the computer via USB, it WON'T be recognised as such, but it you open Windows File Explorer, you will see it as a Volume in the left hand side pane. Drag music to a folder and drop music in from there.
http://portablemedia.manualsonline.com/manuals/mfg/osram_sylvania/smp2012.html
