20 Most Recent
Sylvania SMPK8854 Digital Media Player Questions & Answers
Can't figure out how to play videos on my mp3 player???
To copy movies, they have to be converted to avi, even if they are avi already, there is an avi converter
On the cd that came with your player, you can also download the driver cd from curtisint.com if you don’t have the cd.
other converters will work if you have the correct settings.
You can’t just copy or drag a movie to the player unless it has been converted first, convert it to a destination on your computer, it will convert faster.
Don’t select your player as the destination when converting movies/videos, convert then copy to player.
7/8/2021 4:42:47 AM •
Sylvania...
Answered
on Jul 08, 2021
What picture format is needed
For your Sylvania SMPK8854 MP3 Player
o AUDIO PLAYBACK FORMATS: MP3, WMA
o RECORDING FORMATS: WAV
o VIDEO PLAYBACK FORMATS: FLAC, AVI
o PICTURE FORMATS: JPG, BMP, GIF
Free file converter: http://formatoz.com/
Free manual and downloads: http://forums.cnet.com/5208-7595_102-0.html?threadID=303811
This is a FREE answer, Please Rate Me
10/9/2015 2:21:41 PM •
Sylvania...
Answered
on Oct 09, 2015
How do I use the mico sd card on this player?
I would recommend here:
http://www.newegg.com/product/ProductList.aspx?N=2070070068+1053118914&Submit=ENE&SubCategory=68&Tpk=micro%20sd
It honestly doesn't matter what brand of micro SD you stick in your MP3 player, so I wouldn't worry too much. Micro SD's are much smaller, so no, you can't use a normal SD in a Micro slot. Most however do have an SD "shell" that you can stick your Micro into, and use just like a normal SD card. Also I know that MOST mp3 players allow you to add pictures, videos, etc, and having a Micro SD inside should allow you to add things directly onto it, so i dont see why you wouldnt be able to access the contents of the Micro from your MP3.
Hope this helps! :)
6/4/2013 11:26:13 PM •
Sylvania...
Answered
on Jun 04, 2013
How can I unfreeze my mp3 player?
Let the battery go dead and then recharge and restart. Or if you have one with two buttons try holding them down at the same time. It may reset it but shouldn't delete anything. It would be the same as using the power button on a desktop rather than turning it off through the control panel. Hope this helps:)
9/20/2012 7:37:47 PM •
Sylvania...
Answered
on Sep 20, 2012
I need the operator manual
Go to www.curtisint.com,click on mp3.In product search box type number only of product and press arrow.In found list tap product under ID.Choose manual to download PDF.
6/4/2012 2:27:29 PM •
Sylvania...
Answered
on Jun 04, 2012
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
3/24/2012 5:47:01 PM •
Sylvania...
Answered
on Mar 24, 2012
How do i change language
None of these answers helped me. I figured it out on my own. After your smpk8854b is powered up, press the bottom right icon. Then press the center icon. Next, press the top selection. And, finally, double tap the word "english". It will now be back to english.
3/22/2012 12:46:02 AM •
Sylvania...
Answered
on Mar 22, 2012
BATTERY DIES FAST ON SYLVANIA MP3
Adjust the "Backlight Time" and "Power Off" settings to conserve battery life if you find that the MP3 player battery dies quickly.
12/28/2011 2:39:39 AM •
Sylvania...
Answered
on Dec 28, 2011
