Philips 46PP9302 46" Rear Projection Television Logo
Kevin Long Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Alignment of the bulbs to converge
Can't converge colors on screen manually, and green is out of alignment. are the bulbs motorized in the housing to converge?
Anonymous
Level 3:
  • Philips Master 3,459 Answers
  • Posted on Mar 19, 2010
Anonymous
Philips Master
Level 3:
Answers
3459
Questions
5
Helped
850011
Points
5558
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
Alignment of the bulbs to converge - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
In the middle of my tv at the bottom the are green blue and red colors what can that be
The three CRTs (green, red and blue) are out of alignment in that location or the convergence circuit has failed altogether. Look in the users menu to see if they have a "converge or convergence" option to do a simple alignment.
If not, download the service manual and follow the instructions on how to do the alignment.
Note: if you can access from the user's menu, but the colors do not move when you try to adjust, then the convergence circuit has failed and will need to be repaired.
My Sony KP-51WS510 is out of color focus. The blues and yellows are separating. I know there are three color bulbs that work together to create all the colors. Could the bulbs be out of alignment from...
Convergence ICs and CK all Pico Fuses around ICs they will look like resistors but will be Green or Yellow 5amp, 6amp, 7amp Fuses. Big Black ICs they will have the PN# on them
ICs STK392-110 use 120s Mats 1-800-628-1118
TV Repair Shop $255.00
1helpful
The picture curves in the top left corner of my tv.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Colors out of alignment
you moved this set huh? alignment is out, magnets slid out of place on align coils the a convergance alignment preformed (sometimes u get lucky and the coils can be put back perfect and then no alignment needed)
Red Alignment problem on a Hitachi 51inch rear projection tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Color out of convergence.
Good Day;
Sounds like the CONVERGENCE IC has failed >STK-110 > 267P155010. TV only Uses one.
Good Luck, big IRISH.
Hitachi 53uwx10b Convergence
The grid (called an overlay) is put in place to fine-tune one of the colors, usually green. Once one color is adjusted perfectly, the other 2 colors are adjusted to match the first color. For example, if the convergence data is completely erased, the tech will set up the overlay and align the green using to the overlay, and then align the red to the green and then the blue to the green. If the alignment is being done after replacing the convergence IC's because one or 2 colors are slightly off in the corners, the green is usually very close to perfect and the use of the overlay is not absolutely necessary. It is pretty easy to align one color using the outer edges of the screen itself. If you do need the overlay it can be purchased from any Hitachi parts distributor such as Herman Panson, Fox or Union Electronics.
3helpful
2answers
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
