Looking for manual for old Sunbeam CoffeeMaster model C30C. Failing that, it looks like a percolator on top of a carafe. How do I get the carafe off to pour the coffee?
Re: Looking for manual for old Sunbeam CoffeeMaster model...
Grasp the lower handle with your right (or left) hand, use your thumb to push up on the upper handle. This will push the top up at an angle and allow the seal to break gradually.
No payment is needed or expected for a general question. Only if you ask for personal one to one expert help will you be asked for payment.
Anyone can ask any question here for free, and anyone can answer a qestion here, for free.
Go to the hardware store and buy a porcelain or stainless steel cabinet knob that will fit over the hole in the percolator top. Discard the screw that comes with the knob and replace it with a shorter (maybe 3/8") stainless steel version (shorter because the top of the percolator is a lot thinner than a cabinet). Then, buy a couple of neoprene washers and a stainless steel fender washer. Prepare the percolator top by using a hammer and a small piece of wood or something to flatten out the metal around where the old percolator top used to fit. Now you can start putting things together--slip the fender washer over the screw, then one of the neoprene washers and put it through the hole in the percolator top from the inside. Then slip the other neoprene washer over the protruding screw and screw the cabinet knob down, sandwiching the whole assembly nice and tight. Finally, tape a dollar to the old plastic percolator top and throw it away so you can say you've thrown away something.
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
