20 Most Recent Avanti Hot and Cold Water Cooler Questions & Answers
2answers
My pioneer water cooler model 900115, it gives
Check the fuses
10/20/2022 10:39:01 AM • Avanti Hot and... • Answered on Oct 20, 2022
2answers
Sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
4/4/2016 1:05:54 AM • Avanti Hot and... • Answered on Apr 04, 2016
3answers
Sunbeam water cooler model# YLR2-5-87H3
water cooler does not run or dispense water
5/28/2015 11:27:14 PM • Avanti Hot and... • Answered on May 28, 2015
2answers
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
9/17/2014 2:55:25 PM • Avanti Hot and... • Answered on Sep 17, 2014
Why does my water cooler keep freezing up
Your thermostat is set to cold or is stuck in the on position, replace or turn it down
8/13/2014 5:07:25 PM • Avanti Hot and... • Answered on Aug 13, 2014
How do you remove cover to get at the taps
Either the taps pull off or unscrew. Think about it, the cover does not fit over the valves, so the valves must be removable .
4/10/2014 12:36:47 AM • Avanti Hot and... • Answered on Apr 10, 2014
Does it have a filter that i need to change
No they don't.
10/18/2013 11:19:45 PM • Avanti Hot and... • Answered on Oct 18, 2013
Hi, my name is Lucia
avanti water dispenser WD50 where is the filter
10/17/2013 12:32:24 AM • Avanti Hot and... • Answered on Oct 17, 2013
2answers
I have a pioneer table top water cooler model
Mine stopped cooling too!!! It is only about 6 months old....
12/20/2012 12:53:24 PM • Avanti Hot and... • Answered on Dec 20, 2012
Sunbeam warm & cold model
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/26/2011 12:34:49 AM • Avanti Hot and... • Answered on Sep 26, 2011
I need to know what king of 5 gallon water jug i
It will work either way....it's just that the cap makes it easier to turn over and not spill
Also if you have a cap you need to have the piercing thing...
heatman101
2/6/2011 7:12:26 PM • Avanti Hot and... • Answered on Feb 06, 2011
Cold water spiget handle broke off . can i get a
Yes. Call Sears parts direct at 1-800-252-1698 or go to repairclinic.com
12/19/2010 6:24:06 AM • Avanti Hot and... • Answered on Dec 19, 2010
Need new faucets for Sunbeam water cooler
hot and cold water have a smel, do I have to clean or replace sonthing?
12/11/2010 2:22:26 PM • Avanti Hot and... • Answered on Dec 11, 2010
Why does my new cooler have a chemical taste in
thats the "stuff"in the filter getting washed out,throw away the first 1/2 doz cups.
11/17/2010 8:29:23 PM • Avanti Hot and... • Answered on Nov 17, 2010
I have a whc-59,no power.
CHECK UPPLY AND MAIL CIRCUIT
11/17/2010 6:30:19 AM • Avanti Hot and... • Answered on Nov 17, 2010
My water cooler not making a cold water, Need to
On a small refrigeration system like that you need very specialized equipment and a ton of experience to make it work...also you will need to find the leak and fix it before filling it will do any good...
You will probably be better off getting a new one...
heatman101
8/13/2010 3:03:08 AM • Avanti Hot and... • Answered on Aug 13, 2010
Hot water valve stuck
Your problem may re related to the recall of that model due to the child proof hot water handle. Go to:
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05018.html
6/29/2010 10:13:20 PM • Avanti Hot and... • Answered on Jun 29, 2010
The water isnt cooling in the dispenser and we
It is oin the refrigeration unit, if it is not the power ie. outlet. Then not much you can cost effectively do. Could be compressor, dirty coils, thermostat or leaking refrigerant. I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
8/26/2009 1:23:37 AM • Avanti Hot and... • Answered on Aug 26, 2009
Avanti Hot and Cold Water Cooler Logo
96 questions posted
Top Avanti Water Filters & Coolers Experts
john h
ZJ Limited
ZJ Limited
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • Avanti Water Filters & Coolers
Most Popular Question
sunbeam water cooler model ylr2 5 87h3
  • Water Filters & Coolers
