Fridge temp. light starts blinking and fridge warms up, the fridge temp won't go below 55* even after plugging and unplugging the fridge. Please help.
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Successfully, I finaly fixed my refridge. I have the same problem like above. I replay heater, 2 sensors, and PBA board also; but it didn't work. The evap-coil is still freezing but the refridge temp goes 55* to 60*. The solution: make sure the drain below evap-coil NOT stuck. Everytime the refridge defrosts, water from evap can't run out. The drain is block. Therefore, it keeps freezing in evap-coil and fan, so it makes fan stop working. I use the air pressure to make the drain clear. Hope, you can fix your! Thanks for read this!
I have the same problem. I was told by my home warranty part cost is over $500, but I have not been able to find anyone that sells it. A temporary solution is to unplug refrigerator, remove the panel at the back side of the freezer and defrost the evaporator. You have to slide out the shelves and remove 6 screws. Warm water works pretty well as a fast defrost method. When finished replace the panel and plug back in. My refrigerator works for another 7-10 days before freezing again.
My first symptom was no water from the front, so I pulled the fridge out to check water line, water pressure was fine. Turns out the fridge was frosted up behind the lower shelf which froze up the water for the water line in a white plastic radiator shaped dohickey. Anyway after removing all the shelfs and storage bins I removed 7 screws and carefully defrosted the fridge evaporator coil with a sharper image hair dryer,the plastic housing w/fan was stuck to the ice at the bottom so it took about 40 minutes with the hair dryer. This problem was with the fride portion,no problem with the freezer so far. I tested the fan after defrosting,when you push in the door switch the fan should start in about 10-15 seconds, fan tested fine. I'm going to leave the fride set @ 38 degrees and see what happens over the next few weeks.My fridge is a samsung rs2545sh so others models may or may not be similar. Good Luck, I know I have my fingers crossed.
Temperature light started flashing 40 degrees when I unplugged the fridge and plugged it back in the panel will not light up at all anymore and nothing works except the lights in the refrigerator. There is 1 single light that is lit up on the outside LED panel but that is all. I left it unplugged overnight but when I plugged it in in the morning nothing happened still. Any suggestions? Mine is a RS 2545 SH
One night the freeze door was accidently remained opened and even aafter unplugging the refrigerator the temp didnt go down...mine is SAMSUNG RS2545SH
I am experiencing the same problem. I noticed about a month ago that a couple of cans of soda had frozen, so I turned the fridge temp up a few degrees. I had been traveling and working long hours, the fridget hadn't been opened much and I assumed that was the problem. Then about a week and half ago I noticed that the fridge temp light was blinking, and then over Easter weekend the top shelf seemed lukewarm, while the rest of the fridge seemed fine.
I will see if the fan is frozen, as suggested here, and hopefully that will resolve the problem.
If not, I must set out in quest of finding a repair service...
I have a 3 year old RS2545SH refrigerator bought from COSTCO. For the last few days I noticed that the temperature LED on the front-panel is blinking and the refrigerator is not colloing. Water and ice dispensor is not working either. Can you please give a solution for my problem?
Have a two year old Samsung side by side. A couple weeks ago, the refrigerator side light started flashing at the 34 degree level, during day hours. By morning it would be sloid again. Yesterday morning I got up and the indicator read 43 degrees. I put a solid ice block inside, and the temperature went down to 34. Noe today when I left for work the indicator read 52 degrees. Should i unplug this as from the previous suggestions?
I have the SAMSUNG RS2545SH from Costco also. This is the second time the freezer side temp light has been blinking and everything thaws out. Last time after a day or two it just started working again. Doesn't sound like Samsung cares to fix their product. Mine is only a year old. I will haul it back to Costco if I have to.....
I have the same problem with a different model, RS267LASH. Go to this link
http://forum.appliancepartspros.com/refr...
and check out the procedure (on page two) outlined for forcing the frige into defrost mode.
This will save you from having to live out of an ice chest while the techs scratch their heads as they can't fix the frige. Perform the forced defrost every 24 hours and let it go through its cycle.
I have ordered a new PBA Main Board and that is what fixed the same problem 10 months ago.
