Re: error message f4 fan lt electric double oven model...
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Hello Duane, I am happy to
assist you. Typically, error code F4 indicates a lockout error. Try resetting
the unit by unplugging it or flipping the household circuit breaker off. This
usually clears most false error codes. Wait approximately ten minutes and if
the error code does not clear, I would recommend contacting a professional to
proceed further. Most likely the EOC (electronic oven control) or the Lockout Control
Board on the appliance will need replacing.
F4 is an error code that flashes on
Kenmore electric ovens when the oven's temperature sensor has shorted.
You should check the wiring harness and replace the sensor if necessary.
F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
F0 Defective ERC Replace ERC F1 Defective ERC Replace ERC F2 Oven over heat Replace defective Sensor F3 Oven Sensor Open Check/Replace Sensor F4 Shorted wire or Sensor locate short and correct it or replace Sensor F5 Defective ERC Replace ERC F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground. F7 Shorted or sticking button Clean button or replace ERC F8 Defective ERC Replace ERC F9 Door Latch Error Check latch and latch circuit
Mewood
What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
