Often there is NOT enough output to drive the TV's audio amplifier directly from the earphone's port. You will need a small Pre-amplifier, in between the two, You should also try your "Line Out" as that puts out more signal, than the earphone jack. If that still will not drive it, then toy will need a pre-amp, Radio Shack, or the like will have them. Also ensure your Volume is set high.
Did you change the input on your TV to the correct input?
