John Deere L120. When the mower clutch is engaged (switch pulled outward), the engine dies. Appears to be safety interlock related because the engine will recover if the PTO switch is returned to off. The mower deck has been removed for troubleshooting.
Sounds like the seat switch is bad
Could be PTO switch, seat switch, RIO switch. RIO latch relay, or interconnections thereof.
Sounds like you need the repair manual.
https://imanualonline.com/product/john-deere-l100-l110-l120-l130-repair-manual-instant-download/
I would assume seat switch if not remove clutch from crank shaft, keep plugged in and try, if it still happens then it would be in the key switch,,
I had this problem and it turned out to be a wire to the clutch. check to see if there has been some of the instulation removed from rubbing or the wire may be too short and pulls loose when you attempt to engage the mower. The clutch is at the bottom of the drive shaft where the main pully is to the mower deck.
