SOURCE: conversion of Yamaha gasoline electricazl generator engine to natural gas
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy
your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case
it's most likely less then 12HP. Not sure what size engine you have, as
you didn't say only for the model #? On older Gensets it's harder to
track down the HP rated engine is all.
For your Yami YG4600D Genset there you most
likely will have your choice of at least 4 adapter kits depending on
if you are going to keep gasoline as an option. If you're definitely
NOT going to be ever running gasoline again then there are 1 or 2
adapter kits to choose from.
Use the site links below, and then browse whichever area you want as
there are many options there. The last link listed takes you through
all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be
able to get that adapter kit for a lot less then the $227 to $267 they
are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service
wise at least you will have a starting off point with the wealth of
information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your
adapter kit problem there by following my posting recommendations
above. Also please rate my
troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
SOURCE: Generator won't start
After removing the carb, disassembling and blowing it out (twice) to no avail, got a one gallon can of Gunk Parts and Carburetor dip. Removed the carburetor (again), removed float bowl cover, gasket, float, and needle valve and soaked it in the cleaner for several hours. Blew it out (again) and reinstalled it. Now generator starts on first pull like new!
SOURCE: Yamaha ef2400is generator needs some choke to run
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: yamaha ef1000is was rained on, starts and runs
Sounds like the rectifier got fried. Moisture in these units is a dangerous thing. Even if you feel the unit sat long enough to dry ouit, it sometines will hold moisture in the electrical componants.
SOURCE: Yamaha 5700 homelite generator stopped
Hello Karen,
What you are describing is not good at all.
There are 3 things that can cause what you said.
1) The engine seized due to lack of oil, though this generator should have a low oil shutdown, it may have failed, especially if the generator was being operated off level.
2) The engine has over heated, to the point that it seized.
3) A mechanical failure in the alternator, perhaps a bad bearing, has created a large amount of drag on the engine.
Would you check the oil, and post back where it sits at? Might have other options.
