2007 Toyota Avalon Logo
Posted on Feb 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change cigarette lighter fuse on 2007 toyota avalon. I was able to locate the fuse box but, no fuse labeled cigarette lighter
Anonymous
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Feb 07, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
200
Questions
0
Helped
70373
Points
626
May be labeled Convenience Outlet
1helpful
Where is the cigarette lighter fuse for a Chevrolet City Express LT?
The cigarette lighter fuse for a Chevrolet City Express LT is located in the Engine Compartment Fuse Box. The location of the fuse box varies depending on the year of the vehicle. For instance, in 2003-2007 models, the cigar lighter (power outlet) fuses are numbered 29 (Auxiliary Power Outlets) and 30 (Cigarette Lighter). In 2008-2009 models, they are numbered 33 (Auxiliary Power Outlet) and 38 (Cigarette Lighter). In 2010-2022 models, they are numbered 25 (Auxiliary Power Outlet) and 73 (Cigarette Lighter).
Where is fuse box of cigarette lighter on Toyota previa
Located inside your standard fuse box...labeled cig/ltr may also include other functions...Your owners manual can also pinpoint which fuse controls this. Hope this helps.
2answers
How can I change the cigarette lighter fuse in Toyota Avalon 2005?
Changing the fuse in the fuse box wont solve your problem On the back of the socket that is mounted in the dash that the lighter pushes into has a inline fuse that if over heated will blow. You will have to change the lighter. Toyota wanted close to $70 for a replacement lighter for my Tacoma. I never used the cigarette lighter for cigarett but needed to charge my cell phone so I replaced it with a dash Mount 12 Volt Power Socket for $10. Good luck.
Hello, my cigarette lighter is not working...where is the fuse box located and what type of fuse do i need?
Your owners manual should guide you to the fuse box and fuse location the fuse and even have some spares, is likely labeled "accessory"
What fuse controls 12v outlet for cig lighter?
check the fuse box, look for the acc fuse, others have interior fuse that concerns the radio, lights, panels, and that cigarette lighter... or maybe your cigattere lighter is busted...
1helpful
Is15A fuse the number for 2002 avalon cigarette lighter.
No. the amperage is 15A but if you can open the fuse box it will tell you where it is located if you ned to know.
2helpful
2answers
Where is the fuse box for the cigarette lighter of a 2006 Toyota Highlander?
In the 2006 Model the Cigarette lighter is located behind the small compartment on the drivers side dashboard left of the steering wheel. Simply lower the compartment door (Fuse box cover) and remove it to access the fuses. Jul 2010
RGC
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
