ACER ASPIRE 9302 WSMi erased programs,cannot use eRecovery
Burning
INT15 error
eRecovery must be terminated
Hello. My problem is that i
erased by mistake (i recognise it was big mistake) all ACER ASPIRE
programs. To be exact, Empowering Technology Framework Launcher,with
it`s utilities(eRecovery,eLock,eSettings,etc...) I went to
Acerglobal site(Europe affording area,Panam,etc...)and i downloaded
empowering technology framework,with some utilities only,but i really
couldn`t find the appropriate(for my model)eRecovery utility,so i
installed other eRecovery(for other model !),to reset to factory
settings my model.I followed all instructions(POST BIOS,etc...) and
now,every startup,coming message: "INT15 ERROR.eRECOVERY MUST BE
TERMINATED!" .Have in mind that Acer Support Team is somehow
dissapeared!(no reply!) Sorry for this big text,but i need either Acer appropriate program,or suggestions-proposals(Any help is acceptable). THANKS FOR YOUR PATIENCE.
If you do a restore to Factory Settings from eRecovery, all your data and programs would be erased and your system would return to it's original state of what it was when you purchased, Acer eRecovery restores the factory backup (default Acer preload), so if your machine came pre-loaded with any Windows OS, hope you had configured the eRecovery settings before hand and yes you will loose the Linux O/S install
Acer....gotta love it... You aren't alone when looking for help with Acer's framework technology. What you're going to want to do is use the Msconfig utility to work
around this problem. To start msconfig click on Start, select Run, type
msconfig in the Run text box then click on OK.
Next select the Startup tab when msconfig opens. Look in the list for eRecovery Service
and uncheck it. Select Apply and then OK when done. It will pop a
message that a restart is require for changes to take effect. Restart
the system.
From what I've read, this may or may not completely
fix the INT15 Error eRecovery must be terminated error message. If it
doesn't, go back into msconfig/startup and look to see if PCMService has been unchecked. If so, recheck it, select apply and OK, then reboot.
This was all the info I could dig up so I'm not 100% sure if the suggestions are guaranteed to work.
Go into the msconfig utility> Selective startup> Startup tab>
look for 'eRecovery Service' or it's executable 'check.exe'> click
to UNCHECK> Apply> OK.
I have all the sound drivers but my sound is not working.
What is the problem
