Attach your hose and tire filler. They should be a "quick connect".
Take the larger fitting and kind of slide it back and insert the
smaller fitting. Let go of the slide and pull to make sure you have a
positive connection. It will be easier to connect everything when there is no air pressure. There should be an on/off switch located on the right if the tank is facing you. Plug it in, turn it on and wait for it to fill up. Depending on how much air you need, you might have to put some in and then let the compressor cycle back up to its high pressure.
Let me know if I can help you further.
Mike
