20 Most Recent
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Questions & Answers
Converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
3gal. aircompressor - craftsman model #921153101
This problem is not uncommon with small compressors and the inexpensive plastic regulators they use nowadays. The one surefire way to stop it is ti install in in-line valve before the regulator outlet, even if it involves the double ended & threaded brass soupler so they both fit on. This way you can just turn the handles across the line effectively shutting off air flow. I have two pancake compressors and ended up doing the very thing.
Then when time comes to hook up a hose and tool, just switch the handle back and you have air.
Sirwriter
Craftsman air compressors
It is definitely the little spring steel flappers in the head. They are similar to the reeds in a 2-stroke motorcycle engine -- if you've ever had one. They open up a little to let air in on the down-stroke and close off the air intake port on the upstroke. Probably just a piece of one has broken off and it will allow the compressor to pressurize the tank somewhat depending how much of the flapper has broken off. You will notice that your air gage needle on the compressor pulsates when it comes up to the maximum pressure it can attain with that piece missing.
There are two different sets of the flappers in the head -- one for air intake and one for allowing the newly compressed air into the tank. Buy them both and a new head gasket or "O" ring.
Good Luck, Richard
I have a craftsman air compressor (small) with 2
unplug it and see if you can turn the motor pulley by hand, it should turn freely. If it does, check to see if the motor runs with the belt off. If the motor runs by itself then either the belt was too tight or the compressor is seized.
Air compressor tank will not fill?
STOP. What pressure does the gauge show? If it's higher than it should be, drain the tank and replace the pressure switch. If it's not unusually high, then replace the pressure relief valve.
DO NOT let that compressor run at too high air pressure! A burst air compressor is a TERRIFIC bomb, and can kill you before you know what happened!
Durabuilt Air Compressor oil blowout!l
I have a new Durabuilt Air compressor Model # DP0200604
6 gal. tank, Wp 0f 140psi ; I need a owners manual that I misplaced. Where can I go to down load this item? FLT 04-2010
I used compressor 3 wks ago and worked great.Now
Mike: If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
I have a non oil air compressor will not start
0. Check the outlet it is connected to. (this has gotten me a couple of time with GFI outlets. :-)) If the GFI kicked the last time the unit was used then just reset it and go on with life. If the outlet is live (test with lamp or test gear) then on to 1.
NOTE: One of the most common issues is the start capacitor on the side of the pump motor. If the unit is connected to a power source and the pressure gauge is reading 0 when turned on and does not start at all, this may well be the issue. Otherwise it could by be the pressure switch cutoff is stuck. Locate and lube with VERY thin oil. I like Lock ease it is a petroleum distillate with a suspended graphite power. (DO NOT GET IN CONTACT POINT AREA ONLY IN MECHANICALS TO THE SWITCH.)
1. disconnect unit from power. (I like to hang the plug where I can always see it while working on the unit. If I don't see it when I return to work on the unit I can safely unplug it and go about the repairs if some less thoughtful person plugged it in while I was out.
We will not check the linkage between the pump and the motor to make sure nothing is jammed. With power DISCONNECTED turn the motor pulley to ensure freedom of movement. If this beastie rotates then off to the next step.
2. Check the pressure gauge to ensure that the tank is not actually already full. (Hey I have a Ph.D. and I actually have had this happen early before coffee.) Good hearted ribbing from Lawrence helped me to avoid that one in the years that followed. :-)
3. If the pressure gauge is reading above 50PSI then adjust the output regulator to full open to deliver pressure to the output line. Connect an output line, and a nozzle or other pnu tool to release pressure from the tank. and test for start by fumpping off pressure to 0 at the gauge. Then connect the unit to a power source and turn to the on position.
If this did the trick make sure to dump to pressure after turning the unit off. Take the unit outside and set it on the grass (while wearing eye protection open the petcock on the bottom of the tank. Move the unit around to drain water out of the tank. )
If this did not do the trick then you need to check the start capacitor on the side of the motor, the pressure cutoff switch and the wiring to the motor. Finally the brushes in the motor may have worn to the point that there is no contact at the commutator of the pump motor. The brushes are a pair of carbon blocks that rest against the commutator to supply electrical power to the coils within the motor which results in repelling and attracting magnetic fields and thus rotary motion. You can pickup the replacement brushes at a sears repair center or a very well stocked hardware store. (I just LOVE those places)
Let me know if this got you squared away. If not, then supply me with the results of these tests and I'll set you a hopefully more fruitful path.
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/john_28069c9efb56199d
