Make sure that the dvr is not outputting a HD signal to your set - if it is, your set will not work unless you change the signal to 480 from the HD setting.
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
