20 Most Recent Gateway FPD1975W 19" LCD Monitor Questions & Answers
2answers
Monitor not waking up
dont know how old monitor is but it may be time for an upgrade OR the pc/laptop/desktop? may need some setting changes for your wake time, sleep time, intervals, etc.? Sometimes if laptop,, you have to tap the power button to wake up after extended sleep times.
2/8/2019 4:44:51 PM • Gateway FPD1975W... • Answered on Feb 08, 2019
2answers
Theft disable menu pops up and won't go away and
You need to install EZTUNE from Gateway, but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
User manual:
http://www.retrevo.com/support/Gateway-FPD1975W-Monitors-manual/id/1071ag416/t/2/
1/22/2019 1:21:07 AM • Gateway FPD1975W... • Answered on Jan 22, 2019
RGB No Signal Message
First you need to check the cable at both ends, inside and out. Make sure it is plugged in, to the proper connector and that there aren't any bents pins. Now put this monitor on another computer, a laptop will do. Does it come on now? If so then your video card in your machine is bad. If still bad then the monitor has lost it's signal input. This will have to be repaired by a pro. I repair these all the time and it's not as expensive as you might think.
3/30/2016 5:50:51 AM • Gateway FPD1975W... • Answered on Mar 30, 2016
Main menu on the lower right hand side keeps popping up
Sounds like your menu button on the monitor is stuck in the pushed in position. See if that is the problem and use a needle, q-tip with alcohol to pop it back out.
4/29/2015 9:41:32 AM • Gateway FPD1975W... • Answered on Apr 29, 2015
My monitor will not come
Which model 900w or LE1936 ?
This info is usually on a sticker to the side of the stand.
If the 900w: You problem is probably that the capacitors on the power board have gone bad and need replacing. May also have transistor problems.
You would have to open it up to get a better idea.
I can probably tell from a picture.
If it is the LE1936: then it could be a similar capacitor problem, but it is rarer on this model than the 900w
Also on this model, there is a voltage regulator on the vga-dvi board that tends to go bad.
email [email protected]
3/7/2015 10:41:31 PM • Gateway FPD1975W... • Answered on Mar 07, 2015
Screen image is stretched or smeared
I had that problem, after awhile of using mine, the words would appear to be streaking. I bought a new monitor.
9/20/2014 8:38:37 PM • Gateway FPD1975W... • Answered on Sep 20, 2014
My hannspree tv wont turn on but have a power light
It was damaged by the water.
7/28/2014 4:27:09 PM • Gateway FPD1975W... • Answered on Jul 28, 2014
My hannspree lcd tv wont turn on but have a power lighthannspree tv repair
sounds like warrenty time
7/28/2014 10:05:12 AM • Gateway FPD1975W... • Answered on Jul 28, 2014
What is the diameter of a 107 inch circumference circle ?
107/3.14159 = 34.06 (rounded)
7/19/2014 4:26:50 AM • Gateway FPD1975W... • Answered on Jul 19, 2014
My monitor on but no see nothing
check connections, then separate wiring. touching wires create cross-talk of signals.
6/22/2014 5:56:00 PM • Gateway FPD1975W... • Answered on Jun 22, 2014
My desktop computer do not show any data on the monitor insted it only shows the blue light,what should I do?
separate the wiring. touching wires creates cross-talk of signals.
6/22/2014 5:43:30 PM • Gateway FPD1975W... • Answered on Jun 22, 2014
0answers
0answers
382 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
power switch blinking turn
  • Computers & Internet
