hello
due to the fact that this memory card is no longer available, Kingston does not have drivers fo this card . As a matter of fact SD cards normally do come with drivers , as they are conformed in a way that operating systems recognise them once you plug them into the SD slot
i hope this inofrmation helps you make a decsion
some background on this particular SD memory card you have
SDCZ2-512-A10-KT (Discontinued)
Description:
512MB USB 2.0 DataTraveler I write up to 3MBps
Discontinued
Additional Info:
DataTraveler I USB 2.0 Flash Drive Write up to 1.5MBps Read up to 6MBps
Mfgr's System P/N's:
SDCZ2-512-A10 (Kingston)
Form Factor:
USB Flash Memory
Warranty:
5 Yrs†
here are some solutions .
When the problem occurs is a clue as to the cause.
For example, your response to a memory error message depends on whether:
- You have just bought a new computer.
- You have just installed new memory.
- You have just installed new software or a new operating system.
- You have just installed or removed hardware.
- Your computer has been running fine and you've made no other recent changes.
UNEXPECTED PROBLEMS If your system has been running fine, but suddenly starts to produce memory errors, and crash or lock up frequently, the chance of a hardware failure is more likely, since configuration and installation problems show up as soon as the computer turns on. Sometimes you can get memory problems if your computer is overheating, if you are having a problem with your power supply, or if corrosion has developed between the memory module and the socket, weakening the connection.
HANDLING SPECIFIC PROBLEMS Here is a list of the most common ways the computer informs you of a memory problem.
- The computer won't boot, merely beeps.
- Computer boots but doesn't recognize all the installed memory.
- The computer boots but the screen is blank.
- The computer reports a memory error.
- Memory mismatch error
- Memory parity interrupt at xxxxx
- Memory address error at xxxxx
- Memory failure at xxxxx, read xxxxx, expecting xxxxx
- Memory verify error at xxxxx
- The computer has other problems caused by memory.
- The computer intermittently reports errors, crashes frequently, or spontaneously reboots.
- Registry Errors
- General-protection faults, page faults, and exception errors
