Foxconn 6150BK8MC-KRSH Motherboard Logo
Anonymous Posted on Feb 12, 2008
Switch on back of PSU needs to be turned off and on after restarting Windows XP to successfully POST
I just built a computer with the Winfast/Foxconn 6150BK8MC, and when I restart windows, or shut down windows XP, upon trying to boot it up again, the POST hangs on the part where it recognizes either the Processor, or the next step the RAM. The only way I am able to work around this is to flip the switch on the PSU off for a couple seconds, then turn it back on, then everything boots fine.
I am going to check the RAM, as that was the only common link between the last failing system I had, and this computer. Do you think I should update the BIOS, or reset the CMOS? Thanks.
  • Anonymous Feb 15, 2008
    Hey SirHanz,
    Thanks for your quick response. There is a bios update available; I made a bootable CD to load it up. The RAM is a matched set of 512MB PC2100 DDR, not sure of the density (but have the same sticker labels and specs). I discharged the board by removing the power connection and holding down the power button for like 15 seconds. I still haven't tried it since my first post here, but I have an excess amount of time today, so I will be sure to post back. If my first test preforms as it did before, I am going to run MEMTEST86 on each individual stick and figure this thing out. I'll be back shortly with more info.
Anonymous
Level 2:
  • Expert 145 Answers
  • Posted on Feb 15, 2008
Anonymous
Expert
Level 2:
Answers
145
Questions
Helped
72866
Points
318
If there is an update for your bios I would suggest applying it after you get the system working properly again. It won't hurt to reset the cmos either, also be sure the smaller Ram is in slot A, some motherboards need it this way. Also are your RAM matched, I>E> both high/low density. Running with minimum RAM will rule out some of these questions so disregard any impertanant suggestions, and let us know how you come along.
Foxconn g41md v
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000557
Click on the Tech Support tab, for Drivers
Need guidance in downloading AND installing, post back in a Comment, or Reply; at end of solution
Regards,
joecoolvette
WHERE DO I CONNECT THE PWER SWITCH PIN ON WINFAST MOTHERBOARD
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
I have a problem, winfast k7s drivers needed for win vista
This motherboard does support USB 2.0. Check to see if it shows in the control panel in Windows and reinstall if you find a red stop sign or yellow yield sign. If they do not show check the bios, found when you first start up the computer and make sure they are made active. If active but still not showing, check the cable from the motherboard to the back USB output plate. The manual can be found here for correct pin outs:
http://www.scribd.com/doc/3921691/Foxconn-Motherboard
Good Luck
Working fine until psu packed in, replaced psu, begins power up
The PSU dying may have destroyed the motherboard also. Try removing all interface cards and disconnecting all drives to make sure.
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
2helpful
Winfast k8s755A freezes at startup
Ok I got e-mail from Foxconn and they told me to use a single sided 256 DDR RAM to get past post. So I did, then I wnt to BIOS and set all my settings, saved it restarted turned off the PC then returned my 1GB Ram then all worked just fine. This is an issue coused by haveing a Samptron 64 CPU.
Top Foxconn Computers & Internet Experts
Jose Ramirez
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
