20 Most Recent
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Questions & Answers
I have a winfast foxconn
Hi there.
The memory that your motherboard can take is DDR memory. According to a spec sheet it can take PC2700 (333MHZ) or PC3200 (400MHZ) memory. I hope this helps. If you have a RAM module already in it I would suggest getting one that has the exact same spec.
I need information how to
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download one
cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
hope this helps you
Hi
Hope you can help
As long as it is an ATX compatible power supply increasing the available wattage is not an issue, only meeting MIMIMUM power requirements
You can go to a 500, or even a 750 as long as it has the correct motherboard connections
