Hello. Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator. 1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded. 2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle. 3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes. 4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle. Thanks.
Not an expert but had identical symptoms. Problem was the loosening of the nut 27mm on the main pully. Simply remove lower back panel (16- torx 20 screws ) and tighten same.
If this does not hold over time, the pully hub has been damaged, and a shim, ( shopmade washer ) may solve problem. Remove belt, and pully, look for damage, and install thin shim, so that the nut will not bottem out on bolt before tightening on the pully hub. Good Luck, Lee
Hi, The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Most noises
from a washing machine occur during the spin cycle. If you hear loud
thumping during the spin, the load of clothes may have become
unbalanced. Stop the washer and redistribute the clothes, then re-start
it. Repeat these steps if necessary.
