The Ortho AllClear Cordless Power Mister charging cord requires a 5V DC power supply with a micro USB connector. You can purchase a replacement cord with these specifications at most electronics stores or online retailers. Make sure to verify that the voltage and connector type match the specifications of your device before purchasing a replacement cord.
Ok. I had this issue with my android. the screen used to flash for the entire day and nothing that I tried work. the following list were the procedure that i tried but all of them fail.
[[LIST=1][*]reset[*]restart[*]full battery[*]replace battery
NONE OF THIS PROCEDURE WORKED. ONLY THE FOLLOWING. use the phone until the phone die completely. then, connect the charger and let it charge until it back to full. turn it on and this should work. if not, then take it to the closest repair services and have them fix it for you. hopefully, this will solve your issue. thanks
sorry I might answer this incorrectly due to the non technical question ?
Are you after the cord that powers the device ? https://www.amazon.com/UpBright-Adapter-Electronics-CVD512a-Compact/dp/B00PVEXXUY
From the specs of this device you need an AC - DC power adapter to power it .
Make sure the input voltage 100v - 240 v matches power point ac voltage.
Try checking the auction site E-XXX. They usually have accessories. Or you could go to RCA and type in your product to see if they sell accessories to your model phone
They are available on eBay for quite cheap, I just did a quick search and they can be had for under $10 including shipping. Depends on the exact model number of your unit, there wasn't a huge selection.
Sorry to tell you, but I had the same problem with my phone except my power cord wouldn't work. This was 2 weeks ago and I still can't find a replacement. I don't know if you have a radioshack in Spain, but that's probably the only place you'll be able to find it. That's where I'm going to look.
