i keep getting a ink cartridge failure and paper jam notice but there is no paper in the machine and the ink cartridges are newly replaced. what else should i do?i keep getting a ink cartridge failure and paper jam notice but there is no paper in the machine and the ink cartridges are newly replaced. what else should i do?
You can't post conmments that contain an email address.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the printer, wait for the printer to prompt that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime the ink cartridges. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted. If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Ink system failures is a very serious problem on HP printer systems. If
you have this problem you should be ready to replace your printer.
However there are still troubleshooting steps that you can do to try to
resolve this problem. try this Ink System Failure Trouble shooting guide.
hp printer 8250 gives error 0xc18a0406
checked carrtidges
turn off and back on
check paper jam
