I reinstaled the Windos Vista. The network adapter and bluethoot ys no working They don't have the drivers.
AnonymousApr 14, 2008
Have a wireless G plus MIMO USB adapter,model NUMBER F5D9050B but now have a new laptop. May problem is where a find the drivers of installation this wireless. Please to send my on may email adress; [email protected] Have a wireless G plus MIMO USB adapter,model NUMBER F5D9050B but now have a new laptop. May problem is where a find the drivers of installation this wireless. Please to send my on may email adress; [email protected]
You can't post conmments that contain an email address.
Make sure your network is running and that your set is receiving a good strong signal. Then go to your set menu and use the network menu to set up seet to tv - follow the prompts . If no result, contact mfg to guide you through the exercise. If set is bogus return for another one.
You have to go to "Manage Wireless Networks" and delete the network you are trying to connect to. After that you will be able to reconnect without a problem.
In Control panel find the Network device icon, click to open it and select "open device webpage" This brings you to the seettings, choose wireless and security, in WEP or WPA, create a passkey and apply it (write it down), this will enctrypt the wireless connection, save and exit
Hello! If your are seeting up your wireless connection between your Nintendo DS and your wireless router, you should enter your security key to have a successful connection. If you don't know your wireless network security, you can contact your Internet Service Provider (ISP) to get it.
Are you trying to set up the router ? Or you are trying to connect to the wireless network. It is very easy to set up the router. I hope the following link will help you Click Here for step by step solutions
To the botom right beside the date and time there is a icon which looks like a monitor (it should have a red x throught it) Right click on the icon choose view wireless network(xp) connect to a network(vista)wireless network there in this window you will seet he available network choose your network and select connect,if you have a wep (wireless key) installed, it will prompt for the key.
Good luck
try changing the wirless seeting plug the ethernet cable into the computer when the computer is done registering the internet go to your browser and type in 192.168.1.1 and there it should request a name and password by default its name = admin password = admin and change your wireless settings hope this helps
The wireless LAN feature on your phone works by default.If you are in a wireless enabled environment,just go to your phone seetings and select connections,then select the wireless LAN manager which you must turn on; check the box and click o.k.The phone automatically detects all available networks in that place.You can now connect via a password or free as the case may be. This should be o.k.At the base left of the wireless LAN screen is the tools TAB click on this to show you the network card configuration menu.Here you can view all the available networks and decide on some other vsettings as you please.Remember that if your wireless internet requires a password you may not be able to browse till you enter the correct password.
try seeting the channel to 11. (adjust the channel)
if your wireless network is secured try to disable it for a while to see if that is causing the problem.
try to reset the device by pushing the reset button for 15 sec at the back
(note: important!! by pressing the reset you will loose the informations that you set on the router be sure to know all the settings before resetting the router.)
try updating the firmware of the router to the latest.
seeting may have got lost in yuor network. I would reset the router, and set it up again, It is possible it could have lost your IP.... thats a starter, take your laptop to other places where there is wifi and make sure its not your wireless card.
