2000 Nissan Sentra Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you take back seat out to replace fuel pump on 94 nissan sentra ex car
Michael Thomas
Level 3:
  • Master 3,056 Answers
  • Posted on Jan 06, 2010
Michael Thomas
Master
Level 3:
Answers
3056
Questions
52
Helped
1308214
Points
10935
Hello there:
no this is a intank fuel pump
Location: In-Tank Type: In-Tank, Electric, Direct OE Replacement Condition: New Part#: REPN314501 $70.00
FITS (ENGINE/CHASSIS)
  • 1994: E; 4Cyl 1.6L GAS, FI, VIN "E", GA16DE;
  • 1994: GXE; 4Cyl 1.6L GAS, FI, VIN "E", GA16DE;
  • 1994: SE-R; 4Cyl 2.0L GAS, FI, VIN "G", SR20DE;
  • 1994: SE; 4Cyl 1.6L GAS, FI, VIN "E", GA16DE;
  • 1994: XE; 4Cyl 1.6L GAS, FI, VIN "E", GA16DE;
  • 1994: Limited Edition; 4Cyl 1.6L GAS, FI, VIN "E", GA16DE;
  • Add Your Answer
    Location of fuel pump relay on a 1994 nissan sentra
    On the 94 sentra the fuel pump relay is located under the hood, driver's side to the left of the battery, third slot from the front of the car, should be green in color.
    Where are the fuel filters located in a 2006 nissan sentra 1.8s?
    Here is the best solution i can find, apparently the fuel filter in a 2006 Sentra is connected to the fuel pump in the tank, under the back seat there is an inspection cover that will allow you access to the fuel pump. Here is an ehow link that walks you through the entire process. How to Replace Fuel Filter in Nissan Sentra eHow
    We had our fuel pump changed but noe the car inside stinks of petrol we think the o ring is not put back properly is this dangerous or can we still drive the car as we cant afford to get it fixed
    1984 Nissan Sentra? I believe this fuel pump is mounted on the engine, thats a mechanical fuel pump, you sure its not a 1994? If its a 94, you can change the o-ring yourself if you're up for it. On 94's the pump is mounted under the back seat through an access panel via 4 phillips screws.
    2helpful
    2answers
    Where is the fuel filter located on a 2005 Nissan Sentra?
    fuel filter is part of the fuel pump meaning you have to replace fuel filter and fuel pump as a assembly.
    Does 2005 nissan altima have a access panel above the fuel pump
    not sure about your altima, my daughters sentra tells me to remove rear seat , can gain access to fuel pump for replacement ! call dealer !
    Long crank before engine start on 08 nissan sentra
    You need a fuel pump update kit. Go to your closet Nissan dealership and ask them for a rebuild kit for your fuel sending unit. What has happened is the check ball that keeps gas in the fuel line is not seating well and letting all the gas go back into the fuel tank. So when you try and start the car fuel has to come from all the way in the fuel tank.
    3helpful
    How do I replace a fuel pump on a 2000 Nissan Sentra
    lift the back seat and there should be an acces panel there
    1992 nissan nx owner manul on how to remove the gas tank
    1991-96 Sentra
    See Figures 6 and 7
    CAUTION Fuel injection systems remain under pressure after the engine has been turned OFF. Properly relieve fuel pressure before disconnecting any fuel lines. Also observe all safety practices outlined earlier in the Fuel System Safety Precautions. Failure to do so may result in fire or personal injury.
    1. Following proper procedures, relieve fuel system residual pressure.
    2. Disconnect the negative battery cable.
    3. Drain the fuel tank.
    4. Remove the rear seat cushion.
    5. Remove the inspection cover.
    6. Disconnect the fuel gauge and the fuel pump electrical harness connector.
    7. At the fuel filler door, disconnect the fuel filler tube from the body.
    8. Raise and support the vehicle safely.
    9. Disconnect the ventilation hoses.
    10. Disconnect the fuel outlet, return and evaporation hoses, at the front of the tank and plug the open fuel lines.
    If equipped, remove the tank protector.
    1. Support the tank, remove the fuel tank mounting bolts, and lower the tank from the vehicle.
    To install:
    If the sending unit or the fuel pump are removed, a new O-ring must be installed.
    1. Install the fuel tank to vehicle and torque the mounting bolts to 20-26 ft. lbs. (27-37 Nm). If removed, install the fuel tank protector.
    2. Connect all the fuel lines and ventilation hoses.
    3. Lower the vehicle and connect the filler tube to the vehicle body.
    4. Connect the fuel gauge and fuel pump electrical connections.
    5. Install the inspection cover and rear seat cushion.
    6. Pour fuel back into fuel tank.
    7. Connect the negative battery cable.
    8. Start engine and check for fuel leaks.
    Fig. 5: Exploded view of the fuel tank components-1988-90 4WD Sentra
    Fig. 6: Exploded view of the fuel tank components-1991-94 Sentra/NX Coupe
    Fig. 7: Exploded view of the fuel tank components-1995-96 Sentra
    Hope this help (remember rated and comment this) TY for using Fixya.
    Is there an access door too the fuel pump on a Nissan 2003 Sentra
    You have to remove the rear seat cushion and there is an inspection hole cover over the sending unit and fuel pump. The 2 come out as one unit. Remove the fuel line coupling and then the 6 screws holding the inspection cover on. BE CAREFUL not to bend the level sending arm. If you remove the fuel filter, make sure you mark which way it came of so it cam be put back in the same way.
    Bob 2003 Nissan Sentra SE-R SPEC V
    Top Nissan Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    Arnie Burke
    Arnie Burke
    Are you a Nissan Expert? Answer questions, earn points and help others
