Electrolux Gaurdian, cannot get power to the vacuum itself; cannister is fine and whirring away. Have tried to reset, clear suction, and made sure wheel can spin. Any thoughts?
one) the powerhead is dead legit as in there is no power coming to it or the motor is actually dead.
2) something jammed in the brush and popped the reset button. The reset button is a red button located as your looking at the back of the powerhead on the right side. Usually a red square. Push it and it SHOULD start up again.
That being said, if you have done the reset button and it still does not work, that unit I beleive has either a 2 or 5 year warranty (cannot remember dont have the documentation in front of me) and if it is still covered under warranty for you, take it to your closest Vacuum repair shop. Do take the hose and powerhead with the cannister unit.
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
The dust bag doesnt fit into hose your supposed to out ur bag into the plastic bag holkder then sit inside the canister and this model does not take an ox bag it takes an s bag y
DONT KNOW WHAT THE 5000 CANNISTER LOOKS LIKE BUT MY 2100 IS A PULL BEHIND CANNISTER AND IT WAS SNEAKY. THE LONG PLASTIC STRIPS DOWN THE SIDES HAS A TRACK IN IT. YOU MUST OPEN THE DOOR AND PULL THE STRIP OFF THE TRACK LONG WAYS AND THE TOP HALF WILL SEPERATE FROM THE BOTTOM HALF. BEWARE THE WIRING INSIDE IS JUST LONG ENOUGH AND CAN DISCONNECT EASY. I DONT KNOW IF THIS IS THE SAME BUT NOONE ELSE WAS VOLUNTEERING ANY INFO AT ALL.
