Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
SOURCE: Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
SOURCE: problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
SOURCE: wi-fi connection
1. First, you have to make sure that the Wi-Fi of your laptop is turned on.
2. Make sure that there's an available wireless network in your area so that you can test if the computer can detect any available network.
3. If you're running Win XP, right-click the wireless icon on your system tray and select "View available wireless networks"
4. If you can't detect any wireless network, right-click the wireless icon on your system tray and select Open Network Connections.
5. Right-click the Wireless Network Connection icon and make sure to enable it.
6. If it's already enabled, try to disable it and then re-enable it.
7. If you can't still detect any wireless network, try this:
- Click the Start > Run > type msconfig > hit Enter
8. Locate the Wireless Zero Configuration and click on it once.
9. Once it's highlighted, locate the Start button on the upper left hand corner of that screen.
10. After starting the Wireless Zero Configuration (WZC), try to detect the wireless network again.
SOURCE: No wi-fi signal on Palm Lifedrive
Ok first thing to know is if the LD is detecting networks at all. Tap the wfif icon and hit the scan button. If you see a list of available networks that means its working and the problem is the settings.
I'm assuming that it is detecting the network from your description.
The LD supports WEP and WPA so you have other options if nothing else. WEP is nice and simple (most of the time anyway)
On the scan find your network tap edit, Make sure the SSID is correct, Make sure that it says WEP under scurity and then tap the key box where is says assigned.
Now this is the bit that makes or breaks the connection. Make sure the key type is set correctly. You have three choices hex, ascii or passphrase. Most wireless router just use the first two.
You need to make sure that this is set to exactly the same as the router.
For ten digits that means you are trying to use 40-bit hex which is not the easiest but it works sometimes. Ascii tends to go a lot easier and I would suggest you consider switching over the ascii to avoid the headaches. I don't know why the LD does not want to work all of the time when using the hex key but it does seem to have problems. Assuming you have the hex key matching exactly as per the one you have in the router it should work. Should but sometimes just won't. Check your cases and make sure you are only using the basic ascii set not the extended. Stick to number and letters and you should be good.
I have never had a problem with the ascii or passcode but usually do not have much sucsess with the hex setup even when it is correct. I've assumed that it was something I've missed but have not had these problems using other devices.
SOURCE: sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP
1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then
click control panel. Double-click Network and Dial-up Connections icon, double
click Local Area Connection, and Local Area Connection Properties window will
appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’
2. Select ‘Use the following IP address’, then input the following settings in respective
field:
IP address: 192.168.0.2
Subnet Mask: 255.255.255.0
Click ‘OK’ when finish.
Vista
1. Click the ‘Start’ button (it should be located at lower-left corner of your computer),
then click control panel. Click View Network Status and Tasks, then click Manage
Network Connections. Right-click Local Area Network, then select ‘Properties’.
The Local Area Connection Properties window will appear, select ‘Internet
Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’
field:
Next step for both
All functions and settings of this access point must be configured via the web
management interface. Please start your web browser, and input ‘192.168.0.234’ in the
address bar, and press the ‘Enter’ key. The following dialog should be shown:
Please input user name and password in the field respectively. The default user name is
‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web
management interface of this access point:
NOTE: If you can’t see the web management interface, and you’re being
prompted to input user name and password again, it means you didn’t
input username and password correctly. Please retype user name and
password again.
After you connected to the access point by web browser, the first thing you see is ‘Status
and Information’ page. All system and network related information of this access point
will be displayed here. The information is very helpful when you want to know the
detailed information of your access point, and when you try to fix the communication
problem between this access point and other wired / wireless computer / devices.
You can click ‘Home’ on the left,
This access point can be operated in different modes; you can click ‘Basic Setting’ to
select an operating mode you want to meet for different needs:
You can click ‘Mode’ dropdown menu to select operating mode, and there are 3
operating modes available:
AP Access point mode, allows wireless clients to connect to
access point and exchange data with the devices connected
to the wired network.
Station-
Infrastructure
Enable the Ethernet device such us TV and Game player
connected to the access point to a wireless client.
Universal
Repeater
This product can act as a wireless range extender that will
help you to extend the networking wirelessly. The access
point can act as Station and AP at the same time. It can use
Station function to connect to a Root AP and use AP function
to service all wireless clients within its coverage.
You can hopefully figure it out from there.
Testimonial: "tanks v. much for answer, i'll try it right away"
